Timing belt problem...
Old Jul 11, 2004 | 07:09 PM
sleepin91teg's Avatar
Default Timing belt problem...
Just done putting my head back together, and new cams and valve train in...but i cant get my timing belt on the cam gears...HELP...i know there is a tensioner, but no matter wich way i turn it, it seems the bolt is just loosening up...HELP
Old Jul 11, 2004 | 07:37 PM
mr.beeks's Avatar
Default Re: Timing belt problem... (sleepin91teg)
uh oh...
you might stripped the block.....
Old Jul 11, 2004 | 09:16 PM
mingbling's Avatar
uh oh
Old Jul 12, 2004 | 01:54 AM
Default Re: Timing belt problem... (mingbling)
HUH?
Old Jul 12, 2004 | 02:42 AM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg &raquo;</TD></TR><TR><TD CLASS="quote">HUH? </TD></TR></TABLE>
dont forget that the block is alumminum so if you overtight you could break the bolt or strip the block..
now you have to drill that bolt out rethread the block or use
a repair kit ask your local hardware store about them...
White91EF
Nov 1, 2022 07:26 PM
thewrai6th
Dec 3, 2018 12:34 PM
chope045
11
Aug 15, 2011 11:16 PM
stevew84
Mar 7, 2009 07:36 AM
Metal Head
Jul 24, 2008 03:00 AM
