Tachometer and ECU disagree
My tachometer reads a bit lower than my ECU (at 8500 indicated I'm at 8000-8200 on the ECU, as far as I can tell). Which should I trust?
I'm logging with Neptune
The ECU. If the ECU was "off" from what your engine was actually doing, your car wouldn't be running very smoothly. The stock tach can be off by several hundred RPMs at certain points.
iRIDEdumped
Apr 24, 2005 08:24 AM
It's little disconcerting watching the needle swing so far past redline but at least the TunerView is accurate!
