Switched gm3bar to stock map sensor Help
Old Dec 22, 2011 | 07:12 PM
Cantcatchme's Avatar
Default Switched gm3bar to stock map sensor Help
When I changed map sensors from a GM 3bar back to a stock map the car starts then dies right out? The only way it will run is if I selected the gm 3bar (Motec) setting? Hondata s300.
I have not installed my wb yet and I was wondering that since I have my wb hooked up to my ecu,that might be the reason? My settings are Scalar 602 and the offset is 2. Let me know what you guys think.
If wondering why I switched back is because built/boosted motors oil pump went out now I'm using a b16a obd0 motor and not to many vacuum spots on the intake.
Also could it be that I have the map sensor wires backwards?. 96 civic cx and if you looking at the map sensor they go Yellow/White*, Red/ Black* Green/yellow maybe Green/White.
Old Dec 25, 2011 | 03:54 PM
siregcivic's Avatar
Default Re: Switched gm3bar to stock map sensor Help
unless you can change the map itself then you cant change map sensors
journeyquest
Jul 23, 2014 02:58 AM
insaneconceptz
Mar 7, 2009 01:08 PM
rnbguy
Jan 20, 2008 03:46 PM
aldong
Oct 8, 2006 06:15 PM
zman
Jun 15, 2006 07:40 PM
