S100 Dead Time Calibration
Old Mar 21, 2011 | 06:00 AM
jaylivfortyfive's Avatar
Default S100 Dead Time Calibration
Good Morning,
I bought a hondata s100 for very cheap and the local dyno shop has the ability to interface with them. I was looking at the rom editor and it doesn't offer the ability to adjust injector dead time. When you adjust the injector to a larger size I would assume there is some built in conversion that compensates for the greater latencies experienced with the bigger injectors. My question is what injectors are these based on? Or, how does the s100 compensate dead time?
Thanks,
Josh
Old Mar 21, 2011 | 07:34 AM
HRTuning's Avatar
Default Re: S100 Dead Time Calibration
It uses the stock injector latency values since Hondata has never given access to dead times for the s100. That's to say you can't change it.
Old Mar 21, 2011 | 08:12 AM
mtber's Avatar
Upgrade to s300 if you need access to dead time tables: http://www.phearable.net/shoppingcar...ade-p-169.html
Old Mar 21, 2011 | 09:21 AM
I found this on Injector-rehab for stock latency for honda 240cc injector:
http://injector-rehab.com/shop/lag.html
hyboost
Engine Management and Tuning
Apr 29, 2011 05:09 AM
fullracegsr
Jul 31, 2004 01:14 PM
gsrhatch530
Dec 16, 2003 03:48 PM
spooled b16
May 5, 2003 02:31 PM
Gmedalion
Oct 21, 2001 06:57 PM
