Passing Emissions problem
Old Feb 19, 2025 | 12:28 PM
worley's Avatar
Default Passing Emissions problem
I have a 97 Del Sol with a d16y7 and a skunk 2 intake, header, exhaust. Its tuned on an obd1 ecu but I threw the obd2 one back in there for emissions. The only problem is it throws an Idle air control valve code, p1508. The code is unclearable just stays on no matter how many times I clear it. I have the d16y8 iacv on there as its the one that fits the manifold. Any way I can get the code to clear just to pass emissions without having to throw the old intake setup back on?
Old Feb 20, 2025 | 08:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Passing Emissions problem
Is there a reason why you typed your question out in INVISIBLE INK ??? If you want help, don't be cute... just use the default BLACK font color.
Old Feb 21, 2025 | 07:16 AM
hondamark35's Avatar
the reason you have the code is because the OE Y7 ECU only works with a 3-wire and is not compatible with 2-wire IACVs.
Y8 auto throttle body will get you the 3-wire IACV the ECU is looking for. this will also require wiring changes to make/correct the connections to the ECU.
Old Feb 21, 2025 | 10:22 AM
worley's Avatar
Sorry I think the problem is I am on dark mode on the phone website
kwilson4921
Mar 28, 2024 09:53 AM
1337 Si
Oct 2, 2008 01:59 PM
mike03,95civic
13
Jan 11, 2008 11:20 AM
EGSR-T
Sep 15, 2005 07:54 PM
