Stay obd0 or go obd1?
Honda-Tech Double Platinum Member
Im putting a b18a into my 90 crx and i was wondering if i should stay non obd or if i should go obd1? Im putting this engine in for the sole purpose of boosting it. Ive heard that its better to go obd1 if youre going turbo for some reason....i think it has something to do with hondata? I know that there is a guy on here running hondata with a non obd car so im a litte confused. What are the pros and cons of non obd and obd1? Why is it better to go obd1 for hondata?
Also, can someone on here post a link to a wiring diagram for the obd0 to obd1 conversion? Thanks
Sean
Sean
Re: Stay obd0 or go obd1? (sCeRaXn)
Convert to obd1. There are many threads on the pros/cons...try a search. Here is the pinout:
http://www.boosted.org/ecu/COMPLETE.txt
Re: Stay obd0 or go obd1? (true)
Why not run a Zdyne in there ? , It will plug right in, You will be able to run up to 28 lbs of boost and it is very user friendly. I have tune many cars with the Zdyne including my own and it's works very well.
[Modified by CRVRX, 9:58 PM 1/11/2003]
Re: Stay obd0 or go obd1? (CRVRX)
Thanks for the replys...but what would i not be able to do if i stay non obd? Would there be any tuning problems or anything? Thanks alot.
Sean
Sean
Re: Stay obd0 or go obd1? (Blaze45)
Is the Zdyne as good as Hondata...well i know its not as good but will it be ok for me. Im wanting a streetable car that will hav around 250-280hp MAX. is it as easily tunable as the hondata? Thanks for the reply.
Sean
Sean
Sean
Sean
EF9-G'zer
06-27-2004 08:38 PM
rice4life
07-25-2002 01:59 PM
