need wideband o2 sensor?
Old Apr 22, 2012 | 03:22 PM
Del_Slo_b16's Avatar
Default need wideband o2 sensor?
I have a 95 honda del sol with a b16 obd1 swap it has crower cams and alot of bolt ons. I've been told I need to get a wideband o2 sensor. What is it where does it go and how do I get one?
Old Apr 22, 2012 | 03:30 PM
Dc4LsTeG's Avatar
EK9
Default Re: need wideband o2 sensor?
Search. You dont need one but it won't hurt
Old Apr 22, 2012 | 03:34 PM
grumblemarc's Avatar
The Grumpiest
I'm thinking you really have no clue what you would be searching for. Look for AEM or Innovate widebands. Look to spend about $200.
Old Apr 22, 2012 | 04:52 PM
dunkingmofo's Avatar
Yea widebands aren't check, but help out with you knowing if you have the right AFR. I just bought a brand new AEM one last week and it was 170, nothing cheap about widebands.
Old Apr 22, 2012 | 06:28 PM
how hard are they to install?
Old Apr 22, 2012 | 06:30 PM
http://www.aemelectronics.com/wideba...-gauge-kit-745
would this be what i need?
Old Apr 22, 2012 | 06:43 PM
Yep thats what you would need if you decided its necessary that you need one. Just to save you some money, they have AEM wideband kits on ebay just like that one for 170 instead of buying it straight from AEM website.
Old Apr 22, 2012 | 06:46 PM
Dc4LsTeG's Avatar
EK9
If you have to ask, to hard for you to do. Ive heard good things about aem but I just picked up an innovate one myself
Old Apr 22, 2012 | 07:13 PM
DC4LsTeg: obviously i wanna learn. I am no where near a honda person. I have a 2001 ws6 trans am and a 97 audi a4 quattro. Import is a new thing for me. so please instead of trolling like you did in your previous statement please just use your words to maybe say unbolt from exhaust or take off from ____ not trying to start anything just trying to be honest.
Old Apr 22, 2012 | 07:27 PM
Dc4LsTeG's Avatar
EK9
Me trolling.lol. Your the one asking questions that have been covered hundreds of times. You couldve found all your answers by searching.
But heres some more spoon feeding for you
https://honda-tech.com/forums/forced-induction-16/aem-wideband-install-2856442/
Old Apr 22, 2012 | 08:28 PM
Gunmetal_B20_Hatch's Avatar
NGK AFX
/thread
Old Apr 22, 2012 | 08:51 PM
zcme's Avatar
If your not planing on tuning the car, or you don't have a chipped ecu a wide band is next to useless. You just get to watch it go lean or rich but cant do anything about it but cheap tricks like adjusting fuel pressure.
The only reason you need a wideband sensor is if you plan to tune the car.
Old Apr 23, 2012 | 06:37 AM
i do wanna get it tuned and it has crower cams with a basemap on crome...id just like to get it precisioned
Old Apr 23, 2012 | 07:08 AM
Bix VT's Avatar
Installing an AEM wideband: http://www.schnitzracing.com/manuals/AEMWBK.pdf
You will need to get a bung welded into your exhaust for the sensor. Other than that, the instructions above explain the wiring.
And yes, if you want to do any tuning on your own, you'll need a wideband. Datalogging is also reccomended.
Old Apr 25, 2012 | 08:43 AM
beecee18's Avatar
Widebands are good for any performance application where the ecu has been tunes/altered from its factory state, It is there to make sure yourself or your tuner has all the fueling in line and you are acheiving your targeted afr's
I recomend a non permanent application for yourself due to the variety of vehicles you own/drive. Innovate LM-2 can be moved from vehicle to vehicle, Innovate LC-1 is a permanent install per 1 vehicle application, as is the AEM uego, which I like also minus it looks like a f$%#en christmas reef.
Old Apr 25, 2012 | 05:07 PM
The Grumpiest
The AEM isn't really permanent. I can remove this and use it on another car if I chose to.
hawaiieg6
Oct 23, 2011 08:08 PM
icucnme
Mar 20, 2010 10:13 PM
11psiTurboSI
Sep 26, 2006 09:53 PM
11psiTurboSI
May 24, 2005 02:22 PM
underpressure02
Mar 6, 2003 08:32 AM
