Will a h22 with modified internals start on a stock map?
Old Aug 4, 2014 | 02:06 PM
djnikko's Avatar
Default Will a h22 with modified internals start on a stock map?
I have a h22 stuffed into a crx which is running 9:0:1 compression ratio, bigger cc injectors and walbro pump to name a few things. Its also boosted. What im wondering is, if I leave the turbo disconnected would the car start on a stock h22 ecu (p13) or a p28 loaded with a h22 basemap?
Im talking about starting and spluttering, no revs over 3k. I realise its not a good idea to drive it on that map.
Thanks in advance
Old Aug 4, 2014 | 02:32 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Will a h22 with modified internals start on a stock map?
No. Just, no. Not only did you absolutely TANK the stock CR, you didn't tell us anything useful about the injectors, but I'm going to assume they're at least RDX 310's. Even if you did somehow coax it into running, you'll wash your cylinders into oblivion before you've even broken in the motor.
**** no it's not going to run on a stock ECU. Call Xenocron, get a basemap chip made FOR YOUR SETUP. This is super simple ****.
Old Aug 4, 2014 | 02:44 PM
turbohatch96y7's Avatar
Take the wastegate spring out.
Stock injectors
Stock map sensor and you should be good bro
Don't listen to the haterz
Old Aug 4, 2014 | 07:07 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Stock injectors
Co-sign
Old Aug 7, 2014 | 02:33 AM
djnikko's Avatar
Thanks for the replies. I'll give it a go
ktsciv93
Engine Management and Tuning
Feb 23, 2011 01:00 PM
meanshyguy
Aug 10, 2008 08:39 AM
turbogsr18
May 18, 2008 08:00 PM
crispynuggets
33
Jan 25, 2008 01:42 PM
swrdply400mrelay
Jul 2, 2003 09:15 PM
