LS vtec timming.... HELLPPPP!!!!!!
Old Apr 12, 2011 | 01:25 PM
osbunjosh's Avatar
Default LS vtec timming.... HELLPPPP!!!!!!
I have a b16 head on a b18a1 block. Has skunk2 cam gears. The car starts but idles around 2800 rpms and smokes a little. Nothing is wrong with the motor and im positive. A little oil is coming out the exaught in specs but not much at all. Im pretty such its the timming. I dont have any timing belt covers or anything and im stumped. Could someone put in some input?
Old Apr 12, 2011 | 04:45 PM
met-tuning's Avatar
Default Re: LS vtec timming.... HELLPPPP!!!!!!
sounds like to me a you have a worn ring, or burnt piston, or a wore out block
if this a fresh build? if so the rings could have not seated yet as well
Old Apr 12, 2011 | 04:49 PM
osbunjosh's Avatar
i talked to a mechine and he said the "oil coming out of the exaught cause just build up in the headers and exaught. And yes its a fresh build. Just got done and need a guide to get it timed. Thanks a lot
Old Apr 12, 2011 | 10:29 PM
mouab18c1's Avatar
Put a lower timing belt cover on it and time it properly.
Old Apr 13, 2011 | 07:36 AM
met-tuning's Avatar
being its a fresh build I would see your rings have not seated fully yet, let the motor break in for about 500 miles and then change your oil.
also rotate your number 1 pistion to TDC and confirm that your cam gear marks are lined up as well. once the is done confirm that your running 16 degree of ingintion timing
Rich
Old Apr 15, 2011 | 04:00 AM
osbunjosh's Avatar
Okay so i took my motor apart last night and relized there is no valve cover gasket but that is not causing the problem. The cam gears are lined up so the timing is on. What else could it be? causing high idling and smoke. Could i be me using a p28 auto ecu on a 5 speed b16? i think so lol
Old Apr 15, 2011 | 07:58 AM
mouab18c1's Avatar
Cam gears are lined up but is the TDC mark on the crank pulley dead on?
Old Apr 15, 2011 | 08:18 AM
osbunjosh's Avatar
yeah. it cant be the timing. its prefect dead on. Could the computer cause that? cause it is a sohc computer that is chipped or anything. plus its for a automatic and mines a 5 speed. seems like a problem
Old Apr 15, 2011 | 10:06 AM
kyden's Avatar
you think?
Old Apr 15, 2011 | 10:11 AM
osbunjosh's Avatar
i still dont have the timing cover but the cams are right but idk if its top dead center or 180 degrees out so if your standing at the front of the car and turn the crank to top dead center does the pistons come up to the middle or down to the middle. sorry if its confusing. im sorry.
Jeanious
Feb 27, 2008 04:54 PM
jerbear!
May 7, 2005 09:31 PM
accordmurf
Mar 23, 2004 02:30 PM
ysrhatch
Oct 3, 2001 12:32 PM
