Look over this map and datalog for b16a2
Old May 18, 2012 | 07:50 PM
Infamous war's Avatar
Default Look over this map and datalog for b16a2
Ok guys i got a map from a buddy and uploaded to the ecu. It starts and runs but you have to keep giving it gas to keep it running.. Can't get it to idle. Also the map had the cylinder fuel trim for cylinder 4 with 1% and cylinder 3 at 2%. Should i change these to 0?
Something else i didnt understand is when car was running, my ram horn manifold was super hot on the 4 cylinder exhaust exit of ram horn, all the other parts of the ram horn you could touch with out worrying about burning your hand.What would cause that to happen?
Here is my setup
B16a2
Manley H beam rods
CP 10.5:1 pistons b16a2 .020mm over
Supertech Nitrate coated racing valves, titanium retainers, dual racing springs locks
Gsr Cams
63ar t3/t4 turbo
38mm tial wastegate
2.5" downpipe
percision 1000cc injectors
Please help me get the map to a driveable state so i can get the car to the tuner...
Just send me pm with email and I will email them to you
Thanks in advance for the help.
Old May 19, 2012 | 03:30 AM
civickiller's Avatar
Default Re: Look over this map and datalog for b16a2
the engine is semi close to stock specs, id throw a stock b16 map set up with boost columns, add 10% to the map
tobster
Engine Management and Tuning
Sep 18, 2011 03:56 PM
mikegeezy
Nov 16, 2008 12:08 PM
burks
Aug 28, 2007 07:09 AM
SOHCmaster
Apr 18, 2005 03:57 AM
vti2
May 5, 2004 08:00 AM
