how to open .BIN file
Old Apr 5, 2011 | 04:36 AM
qpe's Avatar
qpe
Default how to open .BIN file
like in the topic, someone has dumped a fuel map from my EPROM, its file with .bin extension, I want to show the map to some people but I can't open it with CROME or am I using wrong software ??
Old Apr 5, 2011 | 06:12 AM
met-tuning's Avatar
Default Re: how to open .BIN file
you should be able to view it with a hex editor issue is its not pretty to look at, at all you will need to find what software was used to burn the chip, have you tried uberdata?
how old is this chip? are you using an odb1 ecu?
Old Apr 6, 2011 | 06:19 AM
qpe's Avatar
qpe
it was burn with chip burner from moates with I guess crome, I havent tried uberdata yet, I will do, the chip is sst 27sf512, ODB1 ecu
I have just tried uberdata 1.7
that is what I got
after that error and many more it managed to open it
Old Apr 12, 2011 | 10:35 AM
VegasInvasion's Avatar
I'm Huge In Japan
save it as a .bin from the Burn2 (make sure you're using the right offsets for your chip) and try to import it into a new .bin
quartermilerun
Engine Management and Tuning
Jan 20, 2013 09:30 PM
nightscream
Sep 18, 2011 12:27 PM
AZNracerx1989
Jan 16, 2006 07:41 PM
ATS*Mark
Oct 12, 2004 04:52 PM
