High Imped. to Low Imped.
Old Mar 15, 2013 | 03:54 PM
CKnight90's Avatar
Default High Imped. to Low Imped.
Will the ECU(Hondata S300) adapt if I change from High Impedance to Low Impedance(w/Resistor box)? Or will a tune have to be redone? My old injectors(debating on sending back to FIC to have serviced if changing Impedance wont work without tuning) are FIC 1000cc High Impedance, My new ones are Precision 1000cc Low Impedance(w/Resistor Box).
Thanks.
Old Mar 16, 2013 | 01:12 AM
swordofdoom's Avatar
Default Re: High Imped. to Low Imped.
If your at the same CC you should be fine, but a lot of times different injectors require different dwell settings and opening characteristics.
Old Mar 16, 2013 | 08:49 PM
mtber's Avatar
The ecu won't "adapt". You will need to properly re-scale the injectors, injector dead times and check over the tune with a wideband etc.
MurtazaDSM
Mar 21, 2012 12:14 PM
lsturbo*
Aug 15, 2009 08:50 PM
the.hamburglar
Aug 12, 2007 07:41 PM
ppfalcon
Mar 29, 2006 11:53 AM
BoostedH23a1
Jan 16, 2003 07:20 AM
