Help with turbo timing
Old Nov 22, 2008 | 02:54 PM
ashb82's Avatar
Default Help with turbo timing
I have a F22b1 civic i just added 60-1 to it. i have tuned the NA engine very well.I have advanced the the timing as much as i can with out detonation NA. Can i use this same NA tune but take out -1.5* for every lbs of boost. I am using Crome and as you know it has that option. The reason i want to use this tune is it ran perfect at idle and around town took a while to get it there.
Old Nov 23, 2008 | 03:00 PM
ashb82's Avatar
anybody have advice
Old Nov 24, 2008 | 10:13 AM
sleepgsr's Avatar
Sounds correct. As long as you retard the timing in boost you should be fine.
bnmm
Engine Management and Tuning
Jan 29, 2011 02:52 PM
Benjithx
Jan 13, 2005 11:01 AM
bmm89
Nov 21, 2004 08:17 PM
BoostedD15B7
Jan 25, 2004 08:44 AM
B_1_8_hatch
Jul 28, 2003 01:33 PM
