HELP! p06 vtec conversion now car doesn't run right.
Old May 15, 2011 | 05:17 PM
blake22's Avatar
Default HELP! p06 vtec conversion now car doesn't run right.
I just got done converting my p06 to vtec and now the car barley runs and won't idle. It's a 11F0 board and a xenocron vtec conversion kit. Any advice or help is much appreciated. Thanks.
Old May 15, 2011 | 11:16 PM
mouab18c1's Avatar
Default Re: HELP! p06 vtec conversion now car doesn't run right.
Check your solder joints. Most likely you didn't do a good job.
Old May 16, 2011 | 06:05 AM
HAMOTORSPORTS's Avatar
I hope you don't take this the wrong way, but you socketed and chipped the ECU at the same time right? You didn't just add the VTEC components to a stock ECU correct? Also, any check engine light codes?
Old May 16, 2011 | 03:17 PM
blake22's Avatar
The ecu was already socketed and chipped. I had a f22b2(non vtec) in the car and it was tuned and ran great. Blew it up and put a f22b1(vtec) in and just put the vtec conversion kit in, now it runs like crap. No CEL's.
Old May 16, 2011 | 04:16 PM
mouab18c1's Avatar
Did you put a new basemap on it? Post a picture of both sides of your ecu.
boostdeliquent
Engine Management and Tuning
Dec 8, 2012 05:05 AM
raverx3m
May 30, 2011 06:49 PM
teamitr
Mar 2, 2008 08:30 PM
MiamiEgGSr
Feb 9, 2008 06:24 AM
DevontElan
Jan 30, 2006 04:56 AM
