EMANAGE AUTOTUNE HELP
Old Sep 18, 2010 | 03:02 PM
Spawne32's Avatar
Default EMANAGE AUTOTUNE HELP
I finally got the autotune feature to work on the emanage ultimate, but the biggest problem im having now is that i cant figure out how to do seperate maps for when in neutral and when driving. When driving around the neighborhood it is adding fuel, when in neutral and just revving the engine, it is pulling fuel. So after you come back from driving and the map is all charted for optimum afr using the target af map, it goes apeshit at idle and starts pulling fuel from the same map. Can someone explain this **** to me?
Old Sep 19, 2010 | 12:24 PM
GhostAccord's Avatar
Default Re: EMANAGE AUTOTUNE HELP
That's why most auto-tune functions are completely worthless and should be used sparingly. At least that is the way I look at them.
I'm pretty sure that there aren't separate maps. There may be a drop down menu or idle tool for setting/adjusting the idle fuel and ignition setup. Personally I would say that you need to get your idle dialed in then lock those cells in your map. That way auto-tune won't be able to alter them. I'm not sure if Emanage Ultimate has that feature or not.
Old Sep 19, 2010 | 12:47 PM
non-VTEC's Avatar
autotune is BS...get it on a dyno asap and tune it properly before you melt the engine down.
Old Sep 19, 2010 | 02:09 PM
q16racer's Avatar
tuner > autotune
ashb82
Engine Management and Tuning
11
Aug 3, 2012 01:22 PM
bks84
16
Mar 7, 2012 07:59 PM
scmil95eg
Oct 14, 2009 01:32 PM
millsd4
Aug 17, 2008 03:59 PM
boostaholic
Jul 30, 2002 02:21 PM
