which ecu works?
Also remember that OBD2B integra ECUs have immobilizers, you can simply remove the immobilizer but you will be left with a solid CEL for bad ECU which wont pass emissions in several states, you can also have the immobilizer replaced with a dummy unit that will eliminate the CEL. Also remember to repin A16 to A15 for the fuel pump to work, see below:
camelian
May 5, 2006 02:18 PM
a15, a16, dummy, ecu, honda, immobiliser, immobilizer, imobilizer, obd2b, p75, remove, removing, repin, works
