ECU problem, need help (obd2 to obd1)
Old Oct 17, 2003 | 03:13 PM
Mr.DC2TurBo's Avatar
Default ECU problem, need help (obd2 to obd1)
Hi, I recently did a manual swap in my 01 LS automatic to LS stick. I want the car to be obd1 so I purchased a skunk obd2 to obd1 harness with stock 95 (obd1) ls ecu. Now I can't pass around 6K rpm and I have no idea why. But, when I reuse my stock OBD2 Automatic ecu it works fine and I can rev pass 7K (check engine lite comes up). Anyone know what is up??
Old Oct 17, 2003 | 03:51 PM
Default Re: ECU problem, need help (Mr.DC2TurBo)
need help
Old Oct 17, 2003 | 05:55 PM
Default Re: ECU problem, need help (cbpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbpro &raquo;</TD></TR><TR><TD CLASS="quote">are you using the jumper for OBD2.2 to OBD1 or basic OBD2 to OBD1. that might be the problem there as they are different.</TD></TR></TABLE>
if you are referring to obd2b then yes I'm using that. Anyone know if I can use a 96-98 obd2 ecu in my 01 LS?
dndn
Mar 21, 2009 10:56 AM
getnasty
Dec 26, 2005 07:59 PM
Mr.DC2TurBo
Oct 17, 2003 09:57 PM
gsr squirrel
Oct 8, 2002 06:45 PM
gsr squirrel
Oct 8, 2002 03:59 PM
