ecu help
ok so i just bought a 92 hatch now i got 2 hatches haha sellin one but its a b16a and its on obd0 and i gotta do emissions of course so i need to know what ecu to get and what else i need to get other then distributer. if there is anything else.
thanks
thanks
Sounds like he's saying he has two (Which doesn't matter) but is trying to get emissions done on the old one. PW0 or PR3 are made for the OBD0 B16a. You should already have that ECU.
If it's a 92+ hatch and you're in california, you won't pass anyway.
If you're not in california all they're going to do is run it on the rollers, so as long as you have the right stock ECU for it, it should be ok. If it's chipped, you may not pass.
I still don't get it.. can you please atleast tell me what car you have and what motor is in it?
That way I am not confused about what you are trying to accomplish here. And try putting it in a list format, so it is easy to follow
That is what I was trying to figure out.
What year is the car in discussion?
Washington state or D.C.?
Open the ECU up and check to see if it is chipped or post picture of inside ECU.
Not all states run the rollers, NC only plug and play or you must go to DMV and Court House to get it put on dyno for emissions and get another type of cert. Havent had to prove this yet as I just convert back to OBD2B when needed.
