does anyone know what chip socket this is for?
Old Jan 17, 2012 | 10:40 PM
949's Avatar
949
Default does anyone know what chip socket this is for?
i bought this on this forum and im not sure what the original user used?
crome or something else?
can someone tell me what is used on this ecu?
also is the gray wire supposed to be attached?
if it is what is it supposed to be soldered to?
i got it that way.
the green and white wire is soldered to the board.
also i didnt get a chip, was i supposed to get one?
this is a P06 ecu.
thanks for any help.
Old Jan 18, 2012 | 06:11 AM
VTC_CiViC's Avatar
Default Re: does anyone know what chip socket this is for?
Looks like a standard socket for an Atmel 256 or any other Eprom you'd use for Crome etc..
Old Jan 20, 2012 | 05:00 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Helps to search - looks like someone did some rigging on that board... Read this and it should help you see the possibilities.
http://web.archive.org/web/200711111...nToECUChipping
Old Jan 25, 2012 | 06:22 AM
949's Avatar
949
so this can be used as crome or any other socket version chipset?
Old Jan 25, 2012 | 07:07 AM
DO IT ON ALL FOURS
Correct.
Old Jan 25, 2012 | 01:37 PM
First.EG's Avatar
that area where the green and white wire are is for dataloging
Old Jan 25, 2012 | 02:54 PM
wmac's Avatar
just missing the ZIF socket.
http://www.phearable.net/shoppingcar...cket-p-74.html
Old Jan 25, 2012 | 03:12 PM
DO IT ON ALL FOURS
You don't need a ZIF Socket, it just makes it nicer.
Old Jan 25, 2012 | 03:31 PM
GhostAccord's Avatar
Originally Posted by wmac
The ZIF, or zero insertion force, sockets make it easier to remove and instal chips without bending or breaking the contacts. They are not used with the Neptune RTP, Moates Demon or Hondata. The ZIF is more or less just a bonus if you are continuously changing/burning your EPROM chip.
If you are running a Moates Ostrich a ZIF socket can be kind of a PITA. You will have to remove part of the ribbon connector for the locking arm to rotate. I use a low profile socket when using an Ostrich.
As for the loose wire. If I remember correctly, it should be soldered to pin No. 4 of the CN2 circuit.
GRN - WHT - Blank - GRY - BLANK
Old Jan 25, 2012 | 09:41 PM
949's Avatar
949
thank you so much for the assist.
but do you guys know where the grey loose wire goes to?
Old Jan 26, 2012 | 01:40 AM
Old Jan 26, 2012 | 07:26 AM
949's Avatar
949
totally missed that bro.
+1 for the redirection !
so its going to have two blank spots between the resoldered grey wire.
BlueShadow
Jun 1, 2005 10:08 PM
.H22 POWER.
Apr 17, 2005 07:12 PM
Infinite Auto
Mar 3, 2005 05:47 PM
lv6l
Dec 27, 2004 09:40 PM
jdm4life
Mar 11, 2003 12:39 PM
