Changing wiring harness
Old Oct 15, 2015 | 02:26 AM
Cnorton1112's Avatar
Default Changing wiring harness
Guys I got a 1996 b20b and I am trying to install it in my 1990 civic hatch I need to know what wiring harness I need to get
Old Oct 15, 2015 | 05:16 AM
rice a roni's Avatar
Default Re: Changing wiring harness
This post is in the wrong category, but...
It is really up to you and it depends on which ecu you plan on using. I would recommend using a chipped p28 and since that is obd1, a 92-95 civic harness would be the best harness to use, otherwise depending on which harness and ecu combo you use, you would have a acquire a conversion harness as well.
You will notice that some sensors on the obd2 engine will not be required, such as the knock sensor and the crank position sensor.
Old Oct 15, 2015 | 02:17 PM
Old Oct 15, 2015 | 02:20 PM
I have one out of an Acura ls integera and its obd 1 but what I am not understanding is I have a dual point harness so how would I get the obd 1 harness to work in my car
Old Oct 15, 2015 | 05:52 PM
F22Master's Avatar
Use the harness that came with the car, and modify it for multi point and obd1.
Google is your friend.
93JDMEGG
Nov 3, 2009 07:16 AM
oneforce
Apr 24, 2006 10:21 AM
seerxsi
May 10, 2004 06:07 PM
who00knows
16
Sep 23, 2002 08:15 AM
