cannot raise boost with hondata s300?
Old Jul 5, 2013 | 06:03 PM
1320king's Avatar
Default cannot raise boost with hondata s300?
so i have b18c afi manifold tial mvs wastegate 4.3lbs spring 750cc injectors and running s300 v2 boost opition mac pwm solenoid. So the problem is im trying to raise the boost but no matter what duty cycle i put in the fixed duty boost dont go up tried 25% to 50% nothing stays at 4psi. i checked the solenoid wiring it click once i turn the key on and the vac hoses are ran the way hondata tells you to. i dont know what it could be, maybe some settings are wrong. Anyone with info would help thanks!
Old Jul 5, 2013 | 06:25 PM
mtber's Avatar
Default Re: cannot raise boost with hondata s300?
Replied to your email. The settings don't look like your issue.
Check your plumbing.
Old Jul 5, 2013 | 06:51 PM
1320king's Avatar
So in that diagram where dose the side port from the wastegate go?
Old Jul 7, 2013 | 11:01 AM
mtber's Avatar
To positive manifold pressure (intake manifold etc)
98B18C1
Mar 26, 2013 10:35 AM
eaddagwan
Engine Management and Tuning
13
Aug 20, 2009 07:54 AM
Ls-Rturbo
Apr 20, 2004 05:43 PM
BlackThorN
Dec 21, 2003 12:51 AM
dwilson
Jan 23, 2003 09:48 AM
