Can i alternate between two diff. tuned Ecu's ?
Old Aug 30, 2011 | 06:13 PM
dannysolis92005's Avatar
Default Can i alternate between two diff. tuned Ecu's ?
sup HT. I have an stock ITR motor with i/h/e on my 91 civic si. the wiring was made to run the obdII oem ecu. I was thinking of getting the s300 but its out of my budget right now. I was sondering if i could keep using my P73 ecu for daily driving and get a chipped obdI p28 with an obdII-obdI jumper harnes for just track use.Can this be done safely???
thanks!
Old Aug 30, 2011 | 06:31 PM
mtber's Avatar
Default Re: Can i alternate between two diff. tuned Ecu's ?
Yes, you can switch between ecus without issues, however there shouldn't be a need if your chipped ecu is basemaped efficiently.
Old Aug 30, 2011 | 06:48 PM
is a chipped p28 better that my stock p73. reason is most shops i have asked say they always use the itr base map. will it be worth getting an s300 on my internally stock motor? i plan to get the slightly bigger prelude injectors.
Old Aug 30, 2011 | 07:16 PM
mtber's Avatar
You don't need larger injectors on your stock engine setup.
If you were running a completely stock engine, with a stock cat, stock intake, stock header, the p73 would be ideal. If you are running an intake, header, exhaust, no cat etc.. a chipped obd1 vtec ecu would be ideal.
The best bang for the buck would be a chipped obd1 vtec p28 spec ecu & having it dyno tuned using the re-programmable eprom chip.
Hondata s300 is great, but it is expensive and a bit over kill for an application like yours.
Old Aug 31, 2011 | 08:41 AM
Thanks I appreciate the help.
Old Aug 31, 2011 | 09:23 AM
SQ is the SQUAD's Avatar
get the chipped ecu. run crome for now. look into the moats 2timer if you want to be able to switch between 2 basemaps.
Old Aug 31, 2011 | 09:36 AM
mtber's Avatar
Re-read his question.
He didn't ask about switching maps.
He asked about switching between a stock p73 and a chipped obd1 p28.
There is no need for a moates 2 timer with his application.
There is also no need to switch between ecus if his chipped p28 has a good tune on it.
Old Aug 31, 2011 | 12:24 PM
i understand what he is asking. but my impression was he wanted a street tune and a strip tune. we as if he has the chipped ecu with a 2timer he wouldent need 2 ecus.
Old Aug 31, 2011 | 05:40 PM
mtber's Avatar
Cool, you do have a good solution to dual tunes on the cheap using a 2 timer etc....
IMO:
If he is running the same fuel on the street & on the track (which he should) with his setup, then there is no reason to have 2 tunes. A properly tuned all motor itr setup like his should get good gas mileage and make solid power when properly tuned on a single tune.
Old Sep 1, 2011 | 08:23 AM
IF.............
i dont know. just giving a suggestion on how to do what he wants to do without the hassle of 2 ecus..........
Old Sep 5, 2011 | 05:02 PM
wow lots of options thanks.
Im leaning towards a p28 chipped ecu. i saw that rywire sells pre maped p28. should i buyg one like that and tell them my info? i know that a dyno tune is better but they are gonna do the same as the rywire ecu which is a burned base map. is there someting im missing beside dyno pulls and switching chips to get the best one. thanks again
Canada96
Engine Management and Tuning
12
Nov 15, 2015 06:29 PM
TolnaPunk
Feb 13, 2005 11:46 AM
mingbling
Feb 27, 2004 10:46 AM
Mike Ockhurts
14
Oct 24, 2003 07:09 AM
SCsol
May 21, 2002 02:47 PM
