Which basemap to start
Old May 10, 2008 | 03:35 AM
gettin it's Avatar
Default Which basemap to start
With. My new setup is a b16 block sleeved and bored to 84 mm. So im wondering in crome which basemap do i need to start with. b16 or gsr? And also, will crome support 1000cc injectors before i make my decison on the 650's. Im running 510's now.
Old May 12, 2008 | 05:01 AM
gettin it's Avatar
Default Re: Which basemap to start (gettin it)
ttt
Old May 13, 2008 | 11:48 AM
gettin it's Avatar
ttt
Old May 13, 2008 | 01:19 PM
Relic1's Avatar
I've always determined the type of basemap from the head and cams, adjusting fuel for more displacement is easy. Ignition timing isn't.
running 1000cc's is not easy to get to idle well, but it can be done.
Old May 13, 2008 | 03:32 PM
gettin it's Avatar
Default Re: (Relic1)
Ok, cool. I already have the 650's coming tomorrow so ill be on those. And then my head is a stock b16, with ctr cams. So then i should be starting with the stock usdm b16 map then correct? Do i need to change the cc's for engine size?
Old May 14, 2008 | 06:58 PM
gettin it's Avatar
ttt
Old May 14, 2008 | 11:50 PM
mtber's Avatar
Default Re: (gettin it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gettin it &raquo;</TD></TR><TR><TD CLASS="quote">Ok, cool. I already have the 650's coming tomorrow so ill be on those. And then my head is a stock b16, with ctr cams. So then i should be starting with the stock usdm b16 map then correct? Do i need to change the cc's for engine size?</TD></TR></TABLE>
Yes, you will want to start with a p30 base code, resize your injector multiplier, sync your ignition timing & start tuning from there.
Old May 15, 2008 | 06:11 PM
gettin it's Avatar
Default Re: (mtber)
What do mean by sync my ign. timing? Ive tuned al lil bit not really on a B series. I know how too add the boost options and pretty much everything else. But you lost me on that one. Thanks for the help also.
Old May 15, 2008 | 08:57 PM
Relic1's Avatar
make sure your base ignition timing (with the distributor, a timing light and the service jumper shorted) is the same as the idle area of the map.
Old May 15, 2008 | 10:15 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gettin it &raquo;</TD></TR><TR><TD CLASS="quote">What do mean by sync my ign. timing? </TD></TR></TABLE>
If you have datalogging, you just set the ignition timing at idle to match what Crome says it is running.
Old May 16, 2008 | 08:44 AM
gettin it's Avatar
Default Re: (b19coupe)
OOO!!! Got it. Thanks guys. So pretty much everything will be set at tdc and the dizzy timing at stock for the motor and make sure its the same for crome. Correct.
nix94delsol
Jul 29, 2007 06:52 PM
spuddo01
Mar 23, 2006 11:25 AM
seako_916
May 10, 2004 07:37 PM
