air fuel gauge
Old Jul 20, 2011 | 04:35 PM
bigtom388's Avatar
Default air fuel gauge
i have the hondata s300, does anyone the voltage offset for the aem a/f gauge to make it read though the s300
Old Jul 27, 2011 | 12:16 PM
da_all_day's Avatar
Default Re: air fuel gauge
i dont have the offset buti have the table from the manual. you can try and match up the numbers
Old Jul 28, 2011 | 09:45 AM
likwidchz's Avatar
Hey there,
I don't have Hondata but I have Neptune, but the solution is quite similar, You need to to figure out which available pins on your ecu can be used for an input, and configure that within hondata software then enable the voltage corrections for that input.
You need to wire up a single wire off the wideband and connect that to an input on the ecu and go from there.
--Aaron
carguy0316
Engine Management and Tuning
Nov 9, 2017 09:40 AM
91b18a1ls
Mar 19, 2015 03:44 PM
cantaffordaccord
Jan 17, 2010 11:11 AM
OEM1
May 22, 2008 05:01 PM
nadc2
Sep 17, 2003 10:00 AM
