Accel dfi gen 6
Old Dec 21, 2008 | 03:26 PM
Shavedub's Avatar
Default Accel dfi gen 6
If their are any old schoolers out there that have tuned the accel dfi gen 6 or know anything about it i could use some advice besides get a mega squirt.
I have a .20 over 2.0 16 valve turbo and really want to use the accel. it runs but needs some tunning from some one who knows more than i. Please any thing would get me one step further.
Old Dec 22, 2008 | 08:05 AM
sewell94's Avatar
Default Re: Accel dfi gen 6
What do you need to know about it??
Old Dec 23, 2008 | 02:12 PM
Shavedub's Avatar
I dont know where to start i can get it to run but its not right. i don't know if my base fuel map is right. and my 3 bar map sensor is reading 14 psi to 18 psi at idle and is a new sensor and when i put a 1 bar on it reads maxed out. is that normal will it adjust.
Old Dec 24, 2008 | 06:51 AM
mtber's Avatar
You need to setup the map sensor calibration.
If you can't figure it out I recommend you take the car to a local dyno tuner who can.
Old Dec 28, 2008 | 01:03 PM
Shavedub's Avatar
I didn't see anything in the calmap guide on map sensor calibration. and i live in louisville ky and everyone here thinks they know but really don't. is there anyone you all know who has past experience with accel dfi that i could take my car to and have tuned. i would be willing to tow almost anywhere just to get it driveable. thanks JOE
Old Dec 28, 2008 | 01:36 PM
sander's Avatar
2.7(p/t)
Post up your map sensor voltage charge / relative to pressure.
And see if you can find the map sensor selection screen, see if the voltages are definable and then go from there.
Also make sure your 5V, GND, Sensor, are pinned correctly.
Old Feb 12, 2009 | 12:02 PM
mr2andy's Avatar
I wonder if you have found the solution..
Just in case... have you look under the "global" --> ECU setting and there is a place which you can type in 1, 2, or 3 bar sensor you are using...
maybe that will help.. I'm still running Accel DFI 6 on my car.. nice to find someone on the same boat... it's an old EMS but it works man..!
Old Feb 18, 2009 | 03:39 PM
mikealike's Avatar
if you need some help hit me up as ive been using these units for a long time...mike
11psiGSR
Jul 5, 2023 09:36 PM
sdbee84
Jan 31, 2016 11:20 AM
GT500FTW
Apr 11, 2014 10:15 AM
quickchris
Jul 28, 2006 09:47 AM
shermanyang
May 16, 2003 02:52 PM
