Sol Wont Start
Sol Wont Start
Ok heres the senerio, bought the sol and it was running. i tore the entire engine a part for a rebuild and was ready to start the car and get it back on the road, but now it wont start.....
It cranks over normally has some exhaust fumes coming out, but will not fire. i have already checked spark plugs and they work, fuel is good, pump is working, valves are adjusted properly, all fuses are good and i have no check engine light to look for a code?
does anyone have any ideas?
Thanks
Rob §
Thanks
Rob §
Re: Sol Wont Start
Have you checked whether you have bright spark at all of the plugs?
Is the CEL ON?
Have you double checked the mechanical timing?
Have you measured the cylinder compressions?
Is the CEL ON?
Re: Sol Wont Start
what is the CEL?
Grounds are all good as far as i can see
Timing is perfect
All sparks are very bright i am using Bosch Fusion spark plugs
i have not checked compression i do not have the tool nessasry
Timing is perfect
Re: Sol Wont Start
yes fuel pump turned on its an TRE 255 lph fuel pump brand new and just installed, it did prime and my sol is a 1993
Thanks for the help guys!!
Re: Sol Wont Start
Does the CEL work?
Do you measure battery voltage at the fuel injectors with the key in ON(II)?
Are the fuel injector connectors installed in the correct order?
Are the plug wires installed in the correct firing order on the distributor cap?
Re: Sol Wont Start
Yes the CEL does work but its not throwing any codes
i did not measure voltage at the injectors but the injectors are shooting fuel.
Yes the order is correct
the plug wires are in the correct order according to the haynes Manuel
Re: Sol Wont Start
If the cam and crank are synchronized at TDC1 as shown in the diagram, then the timing is fine. I'm not sure, however, whether it is possible to install the distributor 180-degrees out of phase. You might want to check that. If the distributor is fine, then compression test the cylinders. Is it possible that you have flooded the engine? Does the engine oil have a strong smell of gasoline? If so, drain and refill.
Re: Sol Wont Start
Pull out the spark plugs. Are they wet with gas? Do you see free standing gasoline in the cylinders? If so, drain/dry out the cylinders and then replace the engine oil, which may have been thinned by flooding from gasoline. Thinned oil is less viscous and will lead to low cylinder compression.
Re: Sol Wont Start
Sounds like that will be the next step. Thank you very much i will post in a few about how this experiment goes
Thank you
Rob §
Thank you
Rob §
quad
20
03-14-2007 05:16 AM
