2step?
Old Apr 15, 2008 | 06:55 PM
924doorEG's Avatar
Default 2step?
Okay guys first off, im new to this and just herd about it, and i was wondering exactly what is a 2step? and what dose to help with? i heard that when you have one you can do full throttle launches with it only being at the certen rpm you want it to be? is that right?
Old Apr 15, 2008 | 08:53 PM
dmotoguy's Avatar
Default Re: 2step? (924doorEG)
it is just a rev limiter that is only there during certain conditions that vary by setup.. clutch switch, vehicle speed, etc. you use it to launch from.
Old Apr 15, 2008 | 10:00 PM
98vtec's Avatar
moderator emeritus
it helps for drag racing as it is one less thing to concentrate on when trying to get off the line in due time.
http://www.youtube.com/watch?v=7jLTHFJPzXU
you can set it at any RPM via mph threshold, clutch input, Throttle position..etc
Old Apr 15, 2008 | 10:35 PM
924doorEG's Avatar
very nice....how much do you think it would cost to put on my 92 civic with a p06 ecu?
Old Apr 17, 2008 | 09:12 PM
boostatic's Avatar
Default Re: (924doorEG)
MSD makes a 2-step..that may be the cheapest way to go..unless you do a chipped ecu setup like crome or sumthin like that...
Old Apr 18, 2008 | 06:23 AM
zccr-xsi's Avatar
im just wondering but is that the only resoan why people are chiping there ecus now cause they just want l/c.
MidnightB16
Jan 24, 2009 01:00 PM
dkrex001
Nov 28, 2006 10:48 PM
93FastLs
Nov 2, 2004 07:16 PM
civicguy
Jan 30, 2003 09:57 PM
