Valve Guides
Soo I will be rebuilding my cylinder head on my b16. I am not sure what valve guides are in there now and the head is perfectly fine just wanna switch up valvetrain. I am just wondering if I should use bronze valve guides or is it a big deal to stay oem. I am going to be going supertech valvetrain and making 515whp. Thank!
bronze valve guides dissipate heat better, which is great for racing. but they wear MUCH faster than steel guides.
If you race the car, and hardly ever drive the car, go with bronze.
If you drive the car a lot, go with oem or any decent brand of oem replacement (steel)
Lots of misconceptions here. Bronze guides last longer. Some use a bronzewall insert. You will not see those for a honda I don't think. They are too small, and I would not recommend even buying the tooling to try it, if there is such a thing. Bronze is slick. It almost works like a lubricant. If you go bronze, you NEED chrome stem valves. Without chrome, it will be NOT SO SLICK. As far as the broken guide story, It is very rare to see that. Those stems are tiny, and bend easy. In my machinist experience, I would say it is not at all necessary in a honda to run bronze, because you have no real angle on your rocker arm geometry to excessively wear on the guide like you would a underhead high lift cam.
ruffrhyder
Jul 14, 2008 04:48 PM
