Piston Ring Gap Questions/feedback
Old Mar 16, 2012 | 10:24 PM
  #51
Dc4LsTeG's Avatar
EK9
Default Re: PISTON RING GAP QUESTIONS
Originally Posted by Muckman
You can try and get new rings, postpone your build another week but the new ring set will probably be the same.
This is what I figured to
Old Mar 17, 2012 | 05:48 AM
  #52
blackeg's Avatar
lol this engine assembled yet?
im not 100% convinced that you will bleed off too much compression with those ring gaps. remember you have to spec it out for the most power you plan on making not just the average power. if you do that then when you crank it up your caps will be too tight. i have great compression with my motor and my gaps are .022/.026 @84.5mm
Old Mar 17, 2012 | 09:57 AM
  #53
Dc4LsTeG's Avatar
EK9
Lol no not assembled yet
This is my first build and I have a lot of money into it and I want to make sure everything will be ok before I start assembling it. Just sucks my cars been sitting since November
Old Mar 17, 2012 | 11:11 AM
  #54
Spawne32's Avatar
put it together and run it, everyone else on honda tech seems to be running with 5% or more blow by and seem to be ok with it
Old Mar 17, 2012 | 11:44 AM
  #55
Dc4LsTeG's Avatar
EK9
Yea but I'm not sure if I am, plus I don't want a lot of smoke on startup. Like I said it has to be right the first time, I'm only 19 and if something gets messed up my car will just be sitting forever again cuz I can't afford any more parts
Old Mar 17, 2012 | 12:01 PM
  #56
Dc4LsTeG's Avatar
EK9
Top ring .018"
Second ring .024"
Would that work or is it to big of a difference in the rings?
Old Mar 17, 2012 | 02:29 PM
  #57
blackeg's Avatar
dude i drove a 4 speed toyota tercel when I was that age. dont take this the wrong way but doing all this work to your only car with not much extra cash just isnt the best move. **** happens, it just does. .020 top ring is not enough for it to go blowing oil like crazy when you start it up. put the thing together but really re evaluate your goals. keeping the power lower will in all likelihood prolong its life and reliability...
Old Mar 17, 2012 | 02:47 PM
  #58
Spawne32's Avatar
Top ring .018"
Second ring .024"
if thats what the numbers are, then it sounds fine to me
Old Mar 17, 2012 | 08:21 PM
  #59
Dc4LsTeG's Avatar
EK9
Yea I know teust me I've had Hondas since I was 14 and this isn't my only car. I have an 01 civic sedan as a DD I can't drive my CTR anywhere that it won't be in sight
That isn't what they are. The top is tighter then that. I just dont want a huge gap between the 2 rings when the suggested is .004" between the 2 rings
Old Mar 18, 2012 | 02:23 PM
  #60
Spawne32's Avatar
ok so...what exactly are your ring specs then.
Old Mar 18, 2012 | 02:35 PM
  #61
Dc4LsTeG's Avatar
EK9
The measurements are on the first page of what I got for each one
Old Mar 18, 2012 | 06:56 PM
  #62
Muckman's Avatar
Moderator in Chief
I just installed my rings today. Went with .022 top and .024 second rings. Used .0065/.007 x 3.327" bore.
Old Mar 19, 2012 | 05:09 PM
  #63
Dc4LsTeG's Avatar
EK9
Thanks for the info but your bore is a lot larger then mine so your numbers will come out looser
Old Mar 19, 2012 | 07:02 PM
  #64
Muckman's Avatar
Moderator in Chief
That's why I posted the multipliers.
Old Mar 19, 2012 | 07:11 PM
  #65
Dc4LsTeG's Avatar
EK9
Yes I saw that. What hp are you going for? Will it be a dd?
Old Mar 19, 2012 | 09:07 PM
  #66
Muckman's Avatar
Moderator in Chief
~550, not a DD.
Old Mar 19, 2012 | 09:11 PM
  #67
Dc4LsTeG's Avatar
EK9
Build details? Just for fun lol
Old Mar 20, 2012 | 06:29 AM
  #68
Muckman's Avatar
Moderator in Chief
84.5mm bore, 89mm LS crank
11.5 ~ 12.0:1 compression, Pauter rods
DART big valve head
E85, GT3076R
Old Mar 20, 2012 | 10:24 AM
  #69
Dc4LsTeG's Avatar
EK9
Damn I like the high compression
Old Mar 21, 2012 | 09:33 AM
  #70
Dc4LsTeG's Avatar
EK9
Alright just finished gaping my rings. I went with
Top ring .017"
Second ring .024"
I went with this because with these measurements I had to gap the least amount of rings. Since most of them were at those measurements. So I hope it goes well
Old Mar 21, 2012 | 11:05 AM
  #71
Muckman's Avatar
Moderator in Chief
You used .0055 multipler?
Old Mar 21, 2012 | 12:35 PM
  #72
Dc4LsTeG's Avatar
EK9
Yes for the top ring. Why? Do you think that is to tight? I could still go looser to .018-.019" if that would be better. It's just like I said before though I don't want them to be to loose
Old Mar 21, 2012 | 01:46 PM
  #73
Muckman's Avatar
Moderator in Chief
Ive researched this just as much as you have. At this point I personally wouldn't go any tighter than a .006 multiplier for 4-500hp.
My last engine made 450whp, 84mm bore. I used .020" gap (.006 multiplier) and didnt observe any crazy amounts of blowby or low compression test results.
Spawne and I talked about this offline. His thoughts are to keep it tight if its a street car bc it wont see extended periods of load to heat the rings up and make them expand. But as soon as you go the track (and of course you will), it becomes a race car and will see just as much load & heat. So it makes sense than you build it for the most extreme condition the engine will see, not the everyday. Idealy we want as minimal ring gap as possible but at the end of the day it doesnt seem to matter THAT much and the cost of it being too tight is your motor.
Old Mar 21, 2012 | 01:49 PM
  #74
Dc4LsTeG's Avatar
EK9
That makes perfect sense. What would you think would be good for the top ring then .019"?
Old Mar 21, 2012 | 04:47 PM
  #75
blackeg's Avatar
tell me about it. the cost of my piston to wall being a bit too tight last year was my #3 piston which caught the black death at about 7800rpm on the dyno. ill be damned if that happens again, so this go around i went from .0035 to .0045
