Engine blocks with coolant drains?
Old Oct 10, 2023 | 12:11 AM
chidog's Avatar
Default Engine blocks with coolant drains?
I only know a bit about the Gen 3 CRV engines. As far as I know they don't have coolant drains.
Are there any years or models that do? How stupid not to have block drains. A coolant change
leaves about a half a gallon behind.
After writing this I used a mirror and maybe there is a coolant drain in the block? Does anyone know for sure?
Old Oct 10, 2023 | 05:23 AM
Chance EG's Avatar
Default Re: Engine blocks with coolant drains?
On B series blocks there's a coolant drain plug on the front of the block, and I think one on the back as well.
The one on the front should be right next to where the engine is stamped.
Unless you're talking about a K series engine in which case I have no idea.
Old Oct 10, 2023 | 07:56 AM
chidog's Avatar
Okay, I was looking at a few parts outfits online and the crappy parts photos show various plugs. Then I found a block heater that is available, that would need a threaded coolant hole located some place on the block.
Can't get under it to look yet.
Old Oct 10, 2023 | 08:08 AM
Chance EG's Avatar
Important note, if you plan on threading something in there -
The thread pitch is extremely uncommon. It is M28 x 1mm. Also, if that plug has never been removed in the ~30 years of that car's existence, you can be almost certain that there is a lot of corrosion in the threads. That coupled with the fact that it's a fine thread, high torque fitting means it's extremely easy to cross thread the port.
Go slow, use lots of lubricant, and clean the threads as best as you can before putting in another fitting. Caution should especially be used if the block heater fitting is aluminum/brass which is likely.
https://honda-tech.com/forums/forced.../#post52697228
Old Oct 10, 2023 | 11:23 PM
chidog's Avatar
Not wanting to put anything except the original plug back in. I just want to drain the bad coolant out of the system, and not have a half gallon of water left due to flushing. I used the block heater deal to research if there was a plug someplace on the block, that is all.
Old Oct 11, 2023 | 05:33 AM
Ryanthegreat1's Avatar
The block heater on a K series does not touch coolant. Just a blind threaded bung on the back of the block above the oil filter.
Old Oct 12, 2023 | 07:20 AM
hondamark35's Avatar
aren't the water pump and the thermostat hosing mounted below the water jacket on the front of the block? so changing the thermostat, or at least pulling it out should drain the block completely.
B-series and other CCW blocks can be almost fully drained by pulling a heater hose from the metal tube under the intake manifold.
Old Oct 12, 2023 | 10:18 AM
Yup! Makes a fantastic mess too!
Old Oct 19, 2023 | 06:12 PM
chidog's Avatar
When I get the time will keep researching the drain issue. It will be pretty sad if the only way the cooling system can be totally drained is to remove the water pump, or better yet take out the whole engine and flip it upside down .
Old Oct 23, 2023 | 06:59 AM
spAdam's Avatar
Loved
Community Favorite
Is it not next to the oil filter? It is on Accord K24 blocks.
Old Oct 23, 2023 | 08:04 AM
That's a blind theaded hole on every K series I have looked at. It's where the block heater would go. No communication to the coolant passage.
Old Nov 16, 2023 | 03:59 PM
chidog's Avatar
How brilliant of honda to not have a block coolant drain. I'm sure glad there were smart engineers back in the 1950's that knew how to do things. Its like everything they figured out has been forgotten.
Old Nov 16, 2023 | 04:16 PM
It's an extra $0.25 to drill and tap a hole and another $0.45 for the o-ring and plug.
Over millions of units that's a lot of profit to be had.
Old Jan 30, 2024 | 12:36 AM
chidog's Avatar
Strange the picture calls it a drain plug?
Old Feb 5, 2024 | 04:05 PM
chidog's Avatar
If I ever have to do an overhaul on one of these engines, the first thing I do is machine a proper block drain plug, or two.
Old Jun 26, 2025 | 05:33 PM
walczyk's Avatar
5 Year Member
That’s funny because I just removed this drain plug on my Aunt’s 2005 2005 Honda CR-V and a bunch of coolant came out. There’s a plug with a 10mm Allen hole. It was really easy to get out from above with a 6” extension. I filled the radiator with distilled water and eventually it started draining again from the block drain. I let it all drain out from the radiator and the closed the radiator drain and filled with coolant until it started draining out the engine and then I put the plug back in.
Old Jun 26, 2025 | 05:35 PM
walczyk's Avatar
5 Year Member
You might want to check because mine was a drain plug. You need a 10mm allen socket. just take a photo with your phone if you are unsure
globy123
Nov 26, 2012 01:17 PM
globy123
17
May 11, 2009 08:04 PM
Evolution-93-Ex
11
Jul 2, 2006 11:31 PM
EngineNoO9
Honda Motorcycles
15
Dec 24, 2005 11:54 AM
david90
Aug 26, 2003 09:28 AM
