engine balancing
Old Apr 30, 2007 | 11:05 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
Default engine balancing
is there a difference in balancing your bottom end rotary asembly? i have called 2 different shops one says i need to take them my crank, rods,pistons, wrist pins, rings, and bearings. well the other shop says to take them the same stuff i just said but they need the flywheel and the crank pulley and the clutch and pressure plate. now my question is which is better to do? wat is the difference in the parts they need to balance the crank? any suggestions? thanks
Old Apr 30, 2007 | 11:27 AM
MrParks's Avatar
Default Re: engine balancing (99hondacura)
you will have to provide everything from the clutch assembly to the crank pulley. and everything inbetween to do it right
Old Apr 30, 2007 | 11:30 AM
THCk20eg's Avatar
go to the guys that balance with the pressure plate, flywheel, and crank pulley.
Old Apr 30, 2007 | 11:34 AM
o ok then thanks and one more question wat exactly is the point off balancing? any power gains of doing this?
Old Apr 30, 2007 | 11:38 AM
doood's Avatar
been there done that
Default Re: (99hondacura)
http://laskeyracing.com/shop/balanceengine.htm
good info
Old Apr 30, 2007 | 11:46 AM
thanks for the link helpful information in there
if you dont ming me asking wat is your (doood) about this? and about the link? thank you
Old Apr 30, 2007 | 11:49 AM
doood's Avatar
i have no personal experience with balancing an engine, but what earl says in that link about not balancing with the clutch, flywheel, and balancer makes sense.
Old Apr 30, 2007 | 12:24 PM
95egb18c3's Avatar
Default Re: (doood)
Old Apr 30, 2007 | 01:10 PM
yea i just got done talking to some import shops and they told me the exact same thing thanks for the information i appreciate it!
Old Apr 30, 2007 | 02:20 PM
Jay_Sensing's Avatar
I personally don't have anywhere near the knowledge Earl had, but I have always had my balancer and flywheel balanced with my rotating assemblies and never had an issue with them. Balancing the crank and then throwing on a balancer that has not been balanced with it can throw off the balance of the crank.
If the balancer is doing it's job, it isn't "masking" ****, the rotating assembly all turns as one and since it's metal, it doesn't care how it's balanced as long as it is.
I have fought this battle with helicopters for years with guys, some who use weights, some who don't. I personally use weights and don't see it "masking" anything because my bearings in the heads I balance last a lot longer than those who simply get them within limits and stop because they can't get closer without the aid of weights and refuse to use them.
Balance the crank and flywheel with it. It turns with the motor, no point in not doing it.
Blaze45
Jan 6, 2012 09:17 AM
99_EM1
22
Mar 14, 2009 12:20 PM
hondaeg8
Jan 2, 2004 01:51 PM
H22Chameleonaccord
Jan 14, 2003 02:17 PM
