D16Y8 HEAD STUD TORQUE SEQUENCE
Old Nov 18, 2009 | 02:10 AM
Hoe Hopper's Avatar
Default D16Y8 HEAD STUD TORQUE SEQUENCE
Hey guys i just bought some arp head studs with a new oem head gasket kit for my D16Y8 but it doesnt show the sequence for toqueing down the bolts. I know how many pounds your suppose to torque each bolt at each step but i dont know whats the pattern you have to follow.....Any help guys???
Old Nov 18, 2009 | 06:48 AM
miguel329's Avatar
Default Re: D16Y8 HEAD STUD TORQUE SEQUENCE
http://hondaswap.com/civic-del-sol-e...cations-92493/
Old Nov 18, 2009 | 06:54 AM
miguel329's Avatar
just make sure you use the arp torque spec becuase this is oem torque spec(which is prolly less then the arp required spec)...i follow this spec then last step i torque to requiered arp spec.
Old Nov 18, 2009 | 09:28 PM
Hoe Hopper's Avatar
Thanks alot man.
Old Sep 4, 2010 | 09:14 AM
otek // ek.dipn's Avatar
i thought the bolts are supposed to be tightened down to 22pounds correct? it shows 49pounds is that right? or am i retarded =p
Old Sep 4, 2010 | 09:22 AM
what about taking them off?
Old May 12, 2019 | 08:27 AM
Jaesung's Avatar
its the same as tightening but loosening right?
Old May 12, 2019 | 11:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Nope... loosen in the reverse order. In the diagram above, start at ten and continue backwards to the #1 position. Loosen each one full turn only on the first sequence, then one additional full turn on the second sequence... then you can take them out safely all of the way.
TheNasty0ne
15
Oct 10, 2021 12:19 PM
gonmaro
Jan 29, 2009 12:05 PM
JwithTHEek
Jan 16, 2009 05:44 AM
confidence
Dec 3, 2006 08:45 AM
ArchAngel Sabastian
Jul 12, 2004 11:04 AM
