D16 TDC valves open?
Old Oct 19, 2016 | 11:58 AM
MMMGIRL's Avatar
Default D16 TDC valves open?
The cam on this y8 head is set at TDC, cyl 2 exhaust valves are open and cyl 3 intake valves are open. Is this correct?
Old Oct 19, 2016 | 01:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: D16 TDC valves open?
Some valves will always be open when a camshaft is installed in the cylinder head. At TDC ("UP" mark points at about the 12 O-clock position), all four valves in cylinder #1 should be closed. If you turn the camshaft counter-clockwise 90' ("UP" mark at about 9 O-clock position), then all four valves in cylinder #3 will be closed. 90 more degrees counter-clockwise ("UP" mark now pointing down), then all four valves in cylinder #4 will be closed. Finally, 90 more degrees counter-clockwise ("UP" mark now at about the 3 O-clock position), all four valves in cylinder #2 will be closed. If you remove the cam, ALL valves should be closed.
Old Oct 19, 2016 | 08:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The following link will show you a post that displays what valves are open for each cylinder when each cylinder is TDC. The TDC cylinder is the one firing the spark plug in the picutres. Please follow the link below:
https://honda-tech.com/forums/honda-.../#post50572436
Of which #1 TDC it's fast and easy to see Intake of #3 is open and Exhaust of # 2 is open and both Intake and Exhaust are just barely open on #4.
HondaKing90
19
Feb 15, 2010 04:38 PM
HondaKing90
Engine Management and Tuning
Feb 13, 2010 09:09 AM
Mr.Death
Aug 8, 2006 09:12 AM
jdmkrazie
Jan 12, 2004 07:15 AM
