Failed leakdown after new gasket and resurface
Old 03-12-2017, 05:55 PM
Ridler3d's Avatar
Default Failed leakdown after new gasket and resurface
My d16y8 just recieved a new head gasket and resurface. Problem is when i pressurize a cylinder i get air in the coolant. Im almost convinced that block must be resurfaced. Any input is welcomed.
Do i need to dissassemble the block to have it decked?
should i resurface the head again? 1,000 miles since done last.
Old 03-13-2017, 05:06 PM
motoxxxman's Avatar
Default Re: Failed leakdown after new gasket and resurface
block may be warped, and yes it needs to be completely torn down to resurface.
could have a cracked cylinder too. or the head may be cracked
Old 03-13-2017, 05:10 PM
Ridler3d's Avatar
Thinking a crack would cause a leak from 1 or 2 cylinders, not all 4
Old 03-13-2017, 06:09 PM
Hysterically Calm
TomCat39's Avatar
Have you heat cycled the head gasket? Or is this before running the engine even once after the install?
Old 03-14-2017, 05:09 AM
Ridler3d's Avatar
theres 1,000 on the new gasket
Old 03-14-2017, 06:15 PM
Hysterically Calm
TomCat39's Avatar
Thank you. The way your post read, I and possibly others can't tell if you were pressuring the cylinder immediately after install or after some use (heat cycles) and discovering the reoccurring issue.
joneslchris
06-16-2014 11:51 PM
MrCivic242
03-05-2014 02:04 PM
simpletuning
Classic Hondas
11
10-08-2009 03:53 PM
hatchet_honda
05-16-2009 02:28 PM
arielb1
14
11-03-2004 07:14 AM
Quick Reply: Failed leakdown after new gasket and resurface
