B18c5 help
Old Aug 27, 2018 | 10:21 AM
Jeremy Hoffmann's Avatar
Default B18c5 help
i have a b18c5 bored over to 84mm can I use b20 piston and b18 rods and crank ?
Old Aug 27, 2018 | 11:47 AM
Chance EG's Avatar
Default Re: B18c5 help
I hope you're using aftermarket sleeves if you've bored out a C5 to 84mm.
Otherwise yes you can use B20 pistons and B18B (LS) or B20 rods and crank. Note that oil squirters will need to be removed, and the OEM girdle/mains/main studs will not work.
20
Apr 11, 2013 07:39 AM
dannyneedshelp
Oct 15, 2008 09:22 PM
hondahead87120
Feb 26, 2008 01:20 PM
pootie.teng
14
Aug 25, 2004 04:50 PM
cyrock
Aug 5, 2004 06:26 PM
