B18C1 and B18C5
Old 11-27-2018, 10:47 PM
Brembomaster's Avatar
Default B18C1 and B18C5
Hello all,
I got the Eg9 with B18c engine, but i dun know is it a B18c1 (GSR) or B18c5 (ITR)
are there any marks or component different to know that?
Thanks you
Old 11-27-2018, 10:55 PM
-Intl Steve Krew
Caoboy's Avatar
Default Re: B18C1 and B18C5
Quick ID would be the intake manifold
Old 11-27-2018, 10:59 PM
The intake manifold has replaced.
Old 11-27-2018, 11:04 PM
Chrisfrom1986's Avatar
Quick ID would be the head casting
Old 11-28-2018, 01:05 AM
-Intl Steve Krew
Caoboy's Avatar
Originally Posted by Chrisfrom1986
that’s harder to find!
Old 11-28-2018, 01:07 AM
-Intl Steve Krew
Caoboy's Avatar
with an aftermarket?
then yes, head casting code in the front of the head, under the header would tell you if it’s GS-R or Type R.
also valve springs.
Exhaust manifold as well.
Old 11-28-2018, 03:41 PM
also valve springs.
thanks you for reply.
yes, the intake manifold has replaced aftermarket one by pre owner,
I find this code 98 05 18 05 PR3-1 in the front on head.
I google the code that tell me that should be a type r engine.
Old 11-28-2018, 03:53 PM
Well technically it just means its a B16 or type R head. The year stamp should be 96-01 for it to be a type R. Looking at the piston and rod code will give you a better idea if the block is actually an ITR.
Old 11-29-2018, 05:26 AM
GreatWave's Avatar
The water neck is also a dead giveaway. If it's up front, it's a gsr. Or at least a gsr head.
Old 12-09-2018, 05:05 PM
I have disassembled the engine.
its come with the P73 piston with p72 connecting rod, and i think that is not the ITR crankshaft.
hondalitergsr
02-15-2015 03:03 PM
00em14life
03-10-2011 08:55 PM
IntegraGSR1999
05-15-2009 10:26 PM
lilsaigon510
03-13-2008 04:58 PM
jdm2teg
10-11-2005 09:52 PM
Quick Reply: B18C1 and B18C5
