B18C1 and B18C5
Old Nov 27, 2018 | 10:47 PM
Brembomaster's Avatar
Default B18C1 and B18C5
Hello all,
I got the Eg9 with B18c engine, but i dun know is it a B18c1 (GSR) or B18c5 (ITR)
are there any marks or component different to know that?
Thanks you
Old Nov 27, 2018 | 10:55 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: B18C1 and B18C5
Quick ID would be the intake manifold
Old Nov 27, 2018 | 10:59 PM
The intake manifold has replaced.
Old Nov 27, 2018 | 11:04 PM
Chrisfrom1986's Avatar
Quick ID would be the head casting
Old Nov 28, 2018 | 01:05 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Originally Posted by Chrisfrom1986
that’s harder to find!
Old Nov 28, 2018 | 01:07 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
with an aftermarket?
then yes, head casting code in the front of the head, under the header would tell you if it’s GS-R or Type R.
also valve springs.
Exhaust manifold as well.
Old Nov 28, 2018 | 03:41 PM
also valve springs.
thanks you for reply.
yes, the intake manifold has replaced aftermarket one by pre owner,
I find this code 98 05 18 05 PR3-1 in the front on head.
I google the code that tell me that should be a type r engine.
Old Nov 28, 2018 | 03:53 PM
Well technically it just means its a B16 or type R head. The year stamp should be 96-01 for it to be a type R. Looking at the piston and rod code will give you a better idea if the block is actually an ITR.
Old Nov 29, 2018 | 05:26 AM
GreatWave's Avatar
10 Year Member
The water neck is also a dead giveaway. If it's up front, it's a gsr. Or at least a gsr head.
Old Dec 9, 2018 | 05:05 PM
I have disassembled the engine.
its come with the P73 piston with p72 connecting rod, and i think that is not the ITR crankshaft.
hondalitergsr
Feb 15, 2015 03:03 PM
00em14life
Mar 10, 2011 08:55 PM
IntegraGSR1999
May 15, 2009 10:26 PM
lilsaigon510
Mar 13, 2008 04:58 PM
jdm2teg
Oct 11, 2005 09:52 PM
