B18b1 - Damage
Old Aug 18, 2018 | 06:55 PM
Edgar Gutierrez's Avatar
Default B18b1 - Damage
Hello I currently have a damaged b18b1 block and i just dont know if is worth working with it and if affects the compression. Damage is on the #2 combustion chamber lower area
Old Aug 18, 2018 | 07:03 PM
Default Something wrong with #2 cylinder
i have a b18b1 engine block with a damaged #2 combustion chamber or sleeve whatever you want to call it and i dont know if it will affect the combustion wich it shouldent but just need a second opinion
Old Aug 23, 2018 | 03:42 AM
Txdragon's Avatar
Default Re: B18b1 - Damage
Looks like a rod contacted at some point. That's nothing to be concerned with, that is no worse than a notching for aftermarket h-beams. It'll be fine!
Old Aug 23, 2018 | 01:29 PM
Chance EG's Avatar
Clean it up before re assembly, but it should work out OK. Dremel out the rough spots and make sure you get all the dust/debris out.
Basically just to make sure no small piece ever breaks off and floats through your oil, which is already unlikely but since the block is apart you may as well do some housekeeping.
leeto206
Jul 29, 2013 04:21 PM
8o8_Dc5
Oct 13, 2009 09:37 AM
ge_itr
Jan 17, 2007 06:48 PM
.doeboyfresh.
May 31, 2006 09:21 PM
