B16A3 83mm
Old Aug 6, 2018 | 06:49 PM
Excusetobooost's Avatar
Default B16A3 83mm
Hey guys I believe i found a good deal, but I need advice on what to look for. I found a b16a3 block bored to 83mm darton mid sleeve, crower rods, eagle crank, arias pistons ERL girdle. other goodies..the short block complete 0 miles never used for $1800. I'm going to look at the block before I buy it and I would like some advice on what to look for?? I just want to make sure I dont get screwed. The block looks brand new in the pictures. The guy never finished his project car. Any advice will help thanks.
Old Aug 7, 2018 | 06:42 AM
Chance EG's Avatar
Default Re: B16A3 83mm
Bring a straight edge with you and hold it over the block to try to confirm it has a flat deck.
Shine a light and try to confirm that all the bolt threads are good for the head studs and other accessories, and that nothing has been stripped or helicoiled.
Try shaking a piston with your hand and make sure there's not too much play/movement. Won't really tell you too much unless they used some ridiculously loose p2w clearance, but can't hurt to try.
Ask them if they had the Eagle crank machined before they installed it. I know people have had problems before with buying aftermarket crankshafts (Eagle and Brian Crower in particular I think) where they still have metal shavings or some form of blockage/debris in the oil passages straight from the manufacture before they're installed. Make sure those have been checked and cleaned out.
Old Aug 7, 2018 | 09:01 AM
Thanks for the reply. He mentioned that the rotating assembly was balanced but i will ask about the machining. Also for paperwork from ERL because they did the sleeving. Thank you
Old Aug 7, 2018 | 01:15 PM
Chance EG's Avatar
Also try to rotate the crank by hand just to make sure everything seems gucci with the pistons traveling up and down. Basically just check for obvious problems. You're taking at least somewhat of a risk regardless, but could very well be worth it. That's a decent price for (theoretically) a bulletproof block.
Old Aug 7, 2018 | 03:41 PM
Balor_Gr's Avatar
Id say buy the block and ditch that eagle crank and put an oem inside. Eagle cranks are timebomb.
If its stroked youll have trouble sine you ll also need oem lenth rods.
Muckman
Dec 24, 2014 10:17 AM
TheCrimsonGhost666
Mid-Atlantic (Sales)
Nov 6, 2012 07:53 AM
DC2_117
Nov 18, 2011 11:02 AM
slowassBubble
Jul 1, 2011 04:57 PM
qqqq
Apr 28, 2003 04:41 PM
