3.2 NSX deck #s
Old Jul 15, 2015 | 10:31 AM
Etec Racing's Avatar
Default 3.2 NSX deck #s
I own a 3.2 liter NSX short block and have been looking for specs for allowable deck resurfacing. My factory manuals list just about every number except for this measurement. Any advise on where I can find this spec would be great. Thanks!
Old Jul 15, 2015 | 06:34 PM
birdd's Avatar
Default Re: 3.2 NSX deck #s
Has the block been milled already to your knowledge? Are you looking to just clean up the surface for a rebuild?
Old Jul 15, 2015 | 07:08 PM
Thanks! Someone "cleaned up" the deck with most likely a roloc disc with a fine grit. Since I plan to sell this short block at some point I want be to sure its correct for the new owner.
Old Jul 16, 2015 | 10:19 AM
birdd's Avatar
I think you will be fine taking it down to .005 if need be to clean it back up, just start with .002 and go from there. You should also check how far the pistons come out of the hole on all four corners and cut accordingly to take out any warping of the deck.
Old Jul 16, 2015 | 07:24 PM
PyroProblem's Avatar
IDK much about NSX engines but on B series, there are little circles that are supposedly there to reference how much the deck has been machined.
There little circles that sit just below the deck. When you deck the block enough times eventually you hit them and then that's it.
Do you see anything like that on your block? Mine looks like this.
Old Jul 18, 2015 | 04:40 PM
Runnerdown's Avatar
The cast in dimples don't reference any sort of limitation. It's a very unsubstantiated opinion I have seen time and time again pop up here.
I wouldn't worry about skim cutting the nsx block to renew the surface finish. If the spec is not in the manual then it likely won't be anywhere.
Old Jul 21, 2015 | 04:17 PM
I don't believe I've ever seen any factual data to prove it either. But it kinda makes sense though doesn't it?
I think it's like a go/no go gauge for the deck height limits. Cut as many times as you like until you hit the dimple.
I know someone out there knows what their purpose is...
flycivicsi
Jan 12, 2015 03:24 PM
Rusty Shackleferd
Nov 5, 2007 11:26 AM
aakeobo
Jan 26, 2006 07:31 PM
West Werks
21
Aug 9, 2004 10:36 PM
EIT_certified
Jun 6, 2004 03:32 PM
