Y21 shifting problem
Hey guys i have a problem after i mounted my new clutch.When i wanna putt it in first gear it wont go in butt when i lift the pedal a little bit it works.And when i have it in first gear and hold it at 6500rpm with the pedal to the ground the car moves.And it doesnt shift as smooth with the clutch i had before.And at the track i have big problems to get it in the gears.And i am sure that there isnt any air in the lines.
So i hope you guys can tell me what is wrong because i cant find out the problem.
If the release bearing is going too far in, it could be pushing the pressure plate fingers onto the clutch disc causing it to drag. May need to install a pedal stop. What kind of clutch is it?
Ryanm
Dec 18, 2004 05:19 PM
