Winch setup in trailer
Old Jan 7, 2008 | 08:10 AM
boostedh22a's Avatar
Default Winch setup in trailer
How did everyone go about mounting and wiring their winches inside their trailers???
Old Jan 7, 2008 | 08:12 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Winch setup in trailer (boostedh22a)
mine is in my work box at the front lad bolted to the frame. (open deck)
for what it is worth also i am using a ****** block, it lets the winch not work as hard.
Old Jan 7, 2008 | 08:18 AM
So how is the power wired up??
Old Jan 7, 2008 | 08:23 AM
I thought about just running a 4 gauge wire from the battery of the truck to a quick disconnect on the rear bumper. Then have a lead off of the frame of the trailer to plug into the bumper??? Obviously I can ground it anywhere really.
Old Jan 7, 2008 | 08:29 AM
Yeah I gave that some thought too. Mounting a separate battery in the trailer, and I would assume you just tap into the 12v constant on the trailer plug for charging????
Old Jan 7, 2008 | 08:36 AM
Mr. Badwrench
Default Re: (boostedh22a)
i use a jump box sry.
Old Jan 7, 2008 | 08:37 AM
That would work, I'm just looking to have something more integrated.
Old Jan 7, 2008 | 10:26 AM
jjspec's Avatar
Default Re: (rota92)
I had a wench in my trailer, was cool till the wife found out, lol.
j/k.
Old Jan 7, 2008 | 12:19 PM
skunked's Avatar
Default Re: (jjspec)
I just connect mine to the E-Track system and hook it up to my portable jumper pack.
Old Jan 7, 2008 | 12:41 PM
95integraLS003's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjspec &raquo;</TD></TR><TR><TD CLASS="quote">I had a wench in my trailer, was cool till the wife found out, lol.
j/k.</TD></TR></TABLE>
Good one JJ!
Ill be using ryans open trailer with winch attached to the front!
Ive seen a lot of winchless trailers at the race way.. most just push or drive their cars in!
Old Jan 7, 2008 | 02:53 PM
1992Si's Avatar
Here's the set up in rota's trailer.
Notice the small black box, it has something to do with charging the battery.
Old Jan 7, 2008 | 07:45 PM
I wonder if the black box just charges the battery when you have 110v i.e. the generator hooked up to it???
Interesting setup.
Old Jan 8, 2008 | 04:58 AM
1992Si's Avatar
That's kind of what I'm thinking. But you could take the NAPA part number and check it out.
The trailer also plugs into a 110 outlet on the house.
Old Jan 8, 2008 | 07:23 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if the black box just charges the battery when you have 110v i.e. the generator hooked up to it???
yeah it looks like a trickle charger.
Old Jan 9, 2008 | 04:26 PM
ilovuall's Avatar
when we had the winch and spare battery wired just off the trailer plug the winch was weak so we had to run a seperate wire like stated above
wfocrx
Oct 31, 2014 08:01 AM
nandito
36
Jul 11, 2012 02:54 AM
89efDUSTY
11
Mar 2, 2007 04:51 PM
rasinhell
17
Jul 14, 2005 05:53 PM
mini-cRx
Oct 3, 2002 09:38 AM
