when to shift based on the dyno sheet?
Old Aug 9, 2013 | 08:22 AM
  #26
soloDC's Avatar
Default Re: when to shift based on the dyno sheet?
Originally Posted by MugenSpeclNY
Can you list some
Of these options? Also 14inchx?inch wheel would you recommend?
Mickey Thompson has a 205/50/14 inch tire which has a overall diameter of 22 inches. Also I believe BFG has a 205/50/14 inch drag radial that is a 22 inch tire. I used to run cheap 14 inch honda steelies on the front with the Mickey Thompson 14 in drag radials. I had a 2000 GSR and the steelie wheels cleared the brakes fine. I believe most 14 inch wheels still clear GSR brakes.
Old Aug 9, 2013 | 08:46 PM
  #27
MugenSpeclNY's Avatar
thank you for the reply
what power was your car making and what kind of 60ft's and 1/4 times were you seeing?
EDIT- spec's in ur sig for the teggy is the car your referring to? if so 60ft's?
Old Aug 10, 2013 | 11:26 AM
  #28
soloDC's Avatar
Yeah I'm talking about the car in my sig. On slicks with a open differential GSR trans and 4.9 final I was hitting 1.69 and low 1.7x 60'. On the drag radials I was hitting 2.0-2.1x 60', mostly 2.1s.
Old Aug 10, 2013 | 04:32 PM
  #29
Thanks for the input man
Old Aug 16, 2013 | 05:47 AM
  #30
Honda Bull's Avatar
Originally Posted by raverx3m
im asking more specific about powerband
i know the shift points for the tranny at different rpms
it falls out of vtec regardless from first to second
not asking about gear ratio here
Gear ratio has just as much to do with it as anything else...
Only way to look at it is to take shift points and where they land you in the next gear, start doing weighted averages with the torque numbers (actual torque numbers with the gear ratios involved) and see which way you get the highest average torque number. That's where you want it.
This is of course assuming the rods, valve springs, etc. can handle the RPM you'd be looking for, etc. Obviously if you have a restriction there you have to abide by its rules and you won't get the maximum from the setup.
bluenc-87
Nov 6, 2014 04:27 PM
Fastwhip
Feb 12, 2008 10:18 PM
WPG_5thgenprelude
Oct 3, 2004 01:47 PM
Comptech98GSR
Feb 12, 2002 05:29 AM
REDMAN1322
Nov 7, 2001 06:00 AM
