What rpm to launch at with b18c5 turbo 24.5" slicks
going to the track on sunday. 24.5X8.5X13 slicks. 95 civic coupe b18c5 turbo
324hp to the wheels 267 tq. what rpm should i set the 2 step to, to start with.
tanx
tanx
Re: What rpm to launch at with b18c5 turbo 24.5" slicks (bigstatik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigstatik »</TD></TR><TR><TD CLASS="quote">going to the track on sunday. 24.5X8.5X13 slicks. 95 civic coupe b18c5 turbo
tanx</TD></TR></TABLE>
I used to launch at 7000rpms and 7200rpms, This was with a B16A that made 321whp and 276 ft-lb torque got consistent low 1.7s and once a 1.67 60', I know jinxproof was launching at 8k rpms on some 25x8.7x13s M&H also. Good luck.
Re: What rpm to launch at with b18c5 turbo 24.5" slicks (Boostfed)
like boostfed said, try between 7000-7500 playing with tire pressure between 6.5 lbs and 8.5 lbs. depends on the track, your clutch, and your driving. slip the clutch alittle, don't dump it.
Re: What rpm to launch at with b18c5 turbo 24.5" slicks (jinxproof99)
wow 7500k, i dont want to shear my axles right off.
changing them at the track will suck hard.
seems like 24.5/8.5 is over kill for a car making only 324hp, even if you launch high, im sure youll get some crucial bog before that boost spools in.
Re: What rpm to launch at with b18c5 turbo 24.5" slicks (BustaNutt-616)
i asked all the big time front drag people, they ALL told me 24.5"
thats how i chose.
thats how i chose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 »</TD></TR><TR><TD CLASS="quote">seems like 24.5/8.5 is over kill for a car making only 324hp, even if you launch high, im sure youll get some crucial bog before that boost spools in.</TD></TR></TABLE>
NOPE never bogged a bit, the 22's were too small would have to go into 5th gear and would shred through 1st and 2nd gear. The 24.5s were definately helpful when I switched to them. IMO
Re: What rpm to launch at with b18c5 turbo 24.5" slicks (SlicksMH)
thanx john! hehe, it might not be till next sunday, just tried fitting them on the car.
they dont fit, the car will need to come up, ordering some ground controls.
-jed
-jed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigstatik »</TD></TR><TR><TD CLASS="quote">thanx john! hehe, it might not be till next sunday, just tried fitting them on the car.
-jed </TD></TR></TABLE>
Hehe I could've told you that. 22's fit but not 24.5s Good luck next week then. Car looks good
Re: (bigstatik)
The M&H Slicks look GOOD on the car, the car looks like its going faaaaaaaast just setting their. John@M&H O NICE RIDE One more thing you need to put the stickers on the right and the left side corner of the windows. Black and yellow look sweet on the car.
Re: (bigstatik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigstatik »</TD></TR><TR><TD CLASS="quote">crap, either they got lost or I threw them out by accident. if you send me some more, I will surely put them on the car.</TD></TR></TABLE>
Yeah cuz you know that's 20whp J/K
John& m&h are you guys gonna be a contigency sponsor to any of the sanctioning bodies?
Modified by Boostfed at 8:22 PM 7/6/2003
Re: (SlicksMH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">wow 7500k, i dont want to shear my axles right off.
changing them at the track will suck hard.</TD></TR></TABLE>
a few years ago i was running about 360 hp and 275 tq to the wheels with stock oem gsr axles. ran 100's of passes lasting an enitre year without breaking 1 axle. 24.5 slicks @ between 6.5 - 8.0 lbs of air. clutchmasters stage 4 and quaiffe. do not be scared.
i would never tell someone on here to do something i haven't done myself.
400 HP Club
Re: (jinxproof99)
I ran last friday with 20 psi 20.0x8.0x14 MT and was launching at 5000 - 5600 and a 1.9 60ft, it came out of the whole like a freek, play with the RPM and psi, do a couple of runs and change the set up a little to see what's a better 60ft time. GL have fun.
