What is the optimal advanced ignition?
Old Jul 31, 2010 | 02:46 AM
Pelyvi's Avatar
Default What is the optimal advanced ignition?
Hello everybody!
The successor is the configuration of the engine.
-B16A1 block
-Crower 84.4 crankshaft
-wiseco custom pistons
-about 14:1 CR
-C16 and 100octane petrol mix (50-50%)
-GSR head, S2 PROIII camshafts
I am going with advanced ignition like this currently.
Worthy higher up to raise the advanced ignition? Or he does not make sense?
I accept all ideas, how I can repair the performance.
Thx.
Daniel from Hungary
Old Jul 31, 2010 | 04:07 PM
SOHC_MShue's Avatar
Default Re: What is the optimal advanced ignition?
Have someone that knows what they are doing tune it for you on a dyno.
Old Jul 31, 2010 | 04:17 PM
xenocron's Avatar
www.efi101.com
check out classes and then READ thru the forums
Old Aug 1, 2010 | 10:57 AM
Pelyvi's Avatar
No is dyno. I can set it up on a competition only. Worthy to pull the ignition until the knock border? You are enough the present one 24 degrees of his neighbourhood.
Old Aug 1, 2010 | 02:12 PM
Gunmetal_B20_Hatch's Avatar
wat???
Old Aug 1, 2010 | 03:53 PM
unusual71's Avatar
sometimes adding ignition to the knock border is not necessary because it stops adding power sooner. If you really want to know how much is good talk to other people using your fuel. Most people here only have experience with gasoline, some with C16, but im not sure about a mix.
common amount of timing is like 24-32* but it depends on many variables, without a dyno it will be impossible to get the ignition curve perfect.
alexsracing
Oct 30, 2007 02:00 PM
koczeka
27
Jul 9, 2007 04:34 AM
Johnny_9
Jul 13, 2006 11:16 PM
PrecisionH23a
Sep 29, 2004 08:31 AM
PrecisionH23a
Nov 17, 2002 09:48 PM
