What IGN box/setup do you run?
Old Apr 23, 2011 | 12:59 PM
Ls_dx's Avatar
Default What IGN box/setup do you run?
I am in the market for an IGN box for my new setup. I have my eyes on the new MSD digital 6A box. PN 6201. Will it hang with 30Ish PSI. I dont need alot of features because I can do everything else with the ECU. Was thinking about stepping it up to a digital 7 box, but if the 6a will be sifficient then Ill save some $$ what setup do you have?
mine: Stock dist/ectune/2.0L/id2200/s400-71/e85.
Old Apr 23, 2011 | 01:11 PM
redboost10's Avatar
Default Re: What IGN box/setup do you run?
at least get m&w pro-10
Old Apr 23, 2011 | 01:57 PM
gc8dc95's Avatar
Most people are going to tell you that the M&W stuff is the best. It has a big advantage in eliminating the ignitor. Maybe someday I will make the switch, but for right now I run a MSD Digital 6 Plus with HVC-II Coil. OEM Dizzy, OEM wires, and NGK Plugs. Never had an issue.
As a sidenote, my car is a high 10 at best, so maybe as the power gets turned up my opinion will change.
Old Apr 23, 2011 | 01:58 PM
jdm inc's Avatar
im running the m&w pro 10 works great! no ignition break up or nothing! I was running the digital 6. kept having igniter problems. contact t1 race development the for the pro 10 kit
http://t1raceparts.com/index.php/en/...ro-10-kit.html
Old Apr 23, 2011 | 02:23 PM
2k.civic.si's Avatar
MSD SCI-L with HVC-II coil and my own ignitor replacement.
Old Apr 23, 2011 | 02:50 PM
JJsMotorsports's Avatar
M&W pro 10-------M&W Pro 12 ------and M&W pro DRag.
Old Apr 23, 2011 | 03:27 PM
gogetta's Avatar
Stock ignition can go along way! How much power do you plan to make?
Old Apr 23, 2011 | 03:31 PM
Ls_dx's Avatar
hoping for 800 ish HP
Old Apr 23, 2011 | 04:05 PM
turbo-2nr's Avatar
Pro10
Old Apr 23, 2011 | 04:17 PM
Garage 808 Hatch's Avatar
I was overheating ignitors at 800+ on a msd digital 6 plus.
Old Apr 23, 2011 | 06:20 PM
gogetta's Avatar
I made 700+ on pure stock ignition, but I will be buying pro 10 ASAP. Spark plug gap was like .015 with room to go.
Old Apr 23, 2011 | 09:12 PM
rogueeg6's Avatar
Not to threadjack but if I were to change from just a modded dizzy using an msd blaster coil to running the MW pro10 what all do I need to change. Can the MW be used with the msd coil. I see most using the crane.
Old Apr 23, 2011 | 09:40 PM
1FASTHF's Avatar
Yes but you have to use the "7 series coil" which is the big red one.Im selling my Pro 10 and MSD coil.Pm me if anyone is interested...
Old Apr 23, 2011 | 09:54 PM
Garcia-Racing's Avatar
MSD digital 7 programable w/ HVC2
Old Apr 23, 2011 | 09:58 PM
how far do you have the msd 7 box and the hvc coil from the ecu?
i do like that digital 7 box thats programable
Old Apr 23, 2011 | 10:25 PM
Zer0_SpeedWorks's Avatar
pro10 never looked back
Old Apr 23, 2011 | 10:43 PM
locash's Avatar
M&W Pro10 T1 kit when I was on Hondata, now M&W Pro Drag4.. Get the Pro10, you wont regret it.
Old Apr 24, 2011 | 12:28 AM
boostedcivicsir's Avatar
Mr. Badwrench
6al, blaster ss. 35 psi. never any issues, other than the 7 year old rotor seizing to my old dizzy.
Old Apr 24, 2011 | 04:37 AM
5Star_'s Avatar
M&W Pro Drag 4.We've had multiple issues over heating the ignitor M&W may be pricy but,well worth all the money and headaches
Old Apr 24, 2011 | 06:06 AM
xenocron's Avatar
Please god please if you must go with an MSD (mostly sucks dick) don't go with an analog box.
MW pro 10 ftw
Old Apr 24, 2011 | 08:14 AM
CDecker0218's Avatar
M&W Pro 10 with the crane ps92 coil and harness from t1.
Old Apr 24, 2011 | 08:29 AM
CRX pics below, no problems with interference. Coil is in the engine bay about 12" from the ecu. Sunfire has the ignition box mounted near the drivers side door for last minute adjustments at the line. More pics here. http://www.wiredonhonda.com/vb/tony.php
Old Apr 24, 2011 | 08:31 AM
Old Apr 24, 2011 | 08:57 AM
nonvtecallmotor's Avatar
Same here.
I run FAST and dont need the ignitor.
Old Apr 24, 2011 | 09:59 AM
That is a good box, my buddy just bought the MSD digital 6 and got it installed last night. He was breaking up bad before hand and swapped the MSD iginiton in with new plugs and took care of all the brake up.
