What crank pulley/Harmonic balancer are you running?
#28
Re: What crank pulley/Harmonic balancer are you running? (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">So who are the 7 that are running the fluidamper?</TD></TR></TABLE>
Me
Me
#33
Re: What crank pulley/Harmonic balancer are you running? (hondaguyef)
With a stock balancer you can look at it and see if the rubber piece in the middle is messed up and if the outer ring has slid compared to the inner ring. How can you tell if the fluid damper has lost fluid? If it has or does, will that throw it off?
#36
Soon there will be 8.
#40
Re: What crank pulley/Harmonic balancer are you running? (Quik Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris »</TD></TR><TR><TD CLASS="quote">I'm using the sfi approved 'evolution' pulley-- alternator belt only.</TD></TR></TABLE>
same here
Mike...
same here
Mike...
#43
Anyone running a Fluidampr in an EF?
Is it the Race or Streetdampr line?
How nicely does it play along with a stock crossmember?
#44
Re: What crank pulley/Harmonic balancer are you running? (alexdog69)
On race cars with 16v batterys we don't run a damper since there's no alternator. Just a bunch of washers and the bolt to hold the timing gear in place.
#45
Re: What crank pulley/Harmonic balancer are you running? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">On race cars with 16v batterys we don't run a damper since there's no alternator. Just a bunch of washers and the bolt to hold the timing gear in place.</TD></TR></TABLE>
those washers sfi approved?
#46
hey hondaguy, i am trying to contact you regarding th ctr pistons on ls rods. are they still available? let me know, thanks
#48
Re: What crank pulley/Harmonic balancer are you running? (slimcivic95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slimcivic95 »</TD></TR><TR><TD CLASS="quote">hey hondaguy, i am trying to contact you regarding th ctr pistons on ls rods. are they still available? let me know, thanks</TD></TR></TABLE>
PM'd. go check your IM history if it doesn't pop up. Thanks
Phil
Phil
