running a mile
Old 12-04-2009, 02:59 PM
reddcoupe's Avatar
Default running a mile
have anyone out there ran there car in a mile whats it like whats the numbers just trying to see if its a good idea running a supra in the mile
Old 12-04-2009, 03:46 PM
single cam fan's Avatar
Default Re: running a mile
what kinda power u making? setup? trans?
Old 12-04-2009, 03:58 PM
Mr. Badwrench
boostedcivicsir's Avatar
the supra has 2 things on you, torque, and 6th gear.
if you gear your car right, and have the tq to carry it, it should be a good race.
a honda setup well for the quarter usually traps near redline (i say near because some are different but generally speaking) at the top of 4th gear.
with that said, if you have enough tq to carry 5th, you could probably do it.
unless you plan on running 26" tires hahaa.
we need to know a little more about your setup.
reddcoupe's Avatar
635hp without nitrous and a stock ls tranny
Old 12-04-2009, 04:07 PM
Mr. Badwrench
tires?
go to a gearhead calculator and see where you would be shifting and rev/mph
Old 12-04-2009, 04:15 PM
reddcoupe's Avatar
well its a 00 civic coupe with a fully built ls motor aebs sleeve cp 9-1 piston eagle rods 1000cc injectors walbro 255 intank and bosch044 garrett gt35 water injection 75 shot nitrous thinking of doing the boost by gear the only weak spot right now is my tranny it untouch not even a diff got 15" drag radials or 22" slicks which u think is better for tha asphalt all idea welcomed as i have to do this by next week
Old 12-04-2009, 04:27 PM
Aquafina's Avatar
Do you have an EGT gauge?
Old 12-04-2009, 04:30 PM
rota92
Guest
Posts: n/a
Do it and take vids of the carnage
Old 12-04-2009, 04:36 PM
reddcoupe's Avatar
got a wideband the only carnage a see is that 7m with the 2j swap breaking i tested my car last nite on trust me its scary
Old 12-04-2009, 04:39 PM
rota92
Guest
Posts: n/a
Well in that case go to it, if it's crazy it will kill him
Old 12-04-2009, 05:44 PM
Turbo Wax's Avatar
I recently did that
149mph
163mph
173mph
178.7 mph
Is a LOT of fun
Old 12-04-2009, 06:14 PM
1.5Slowmatic's Avatar
reason auqafina asked is in 5th gear especailly if your spraying thats a TREMENDOUS louad your putting on the motor. Its a good idea to have one to watch if it gets to hot than bye bye motor
Old 12-04-2009, 06:27 PM
ALL IMPORT's Avatar
ya i did a 5th gear pull once on B-line hwy ( hwy that PBIR is off of) its a good 12 miles of STRAIGHT road. has some 17s with some 225/45/17s on them. i can tell u this the mani was deff glowing red i could smell the damn thing & i have never smelt it before, except when it was new. & felt heat. car had about 600hp i think at the time.
some kid wanted to race & after pulling him in 4th my buddy said 'keep going see what it will do", so i buried the tach in 4th at liek 165 & hit 5th for a good 10 -20 sec cant recall & was almost at 9,000rpm & let off. needless to say never again. . then tried opening the window & thought the door was gunna come off, scared the hell out of me ,lol
oh also had to weld some supports on my wastgate flange after that stupid stunt
but cant even imagine spray with that 1 mile is LONG
Old 12-04-2009, 07:11 PM
reddcoupe's Avatar
what if i was to run at about 18psi and start spraying the top of 3rd gear
Old 12-04-2009, 07:14 PM
roadracer4life's Avatar
run an h series with an f series trans.. if i am not mistaken i think 5th gear will get you in the upper 180mph range at 8k rpm
-sam
Old 12-04-2009, 07:25 PM
reddcoupe's Avatar
dam u guys giving me second toughts i dont want to break my engine now
Old 12-04-2009, 07:29 PM
Aquafina's Avatar
Racing a mile on the street (how long to slow down?) and all you're worried about is losing and killing your engine.
Not trying to bash, just pointing it out so you can maybe mull it over.
Old 12-04-2009, 07:31 PM
reddcoupe's Avatar
trust me i got enough time to stop its like a 3 mile strech we rum the mile there all the time
Old 12-04-2009, 07:34 PM
NA James's Avatar
She's gonna be hottt! Take a look at what a f1 engine does at constant rpms. Lots of heat!!!!!
Old 12-04-2009, 07:36 PM
NA James's Avatar
Spray that nitrous on the intercooler the hole time!
reddcoupe's Avatar
will the oil cooler and the water injection help
Old 12-04-2009, 07:44 PM
twkdCD595's Avatar
-sam
a 24" tire and an 8k rpm redline will take you to over 200mph by the math in 5th gear with a 94-97 f series trans.
you playing with fire running 5th gear on a hard load like that though imo.
reddcoupe's Avatar
i have also realized that the block been cooler since i started using q16
Old 12-05-2009, 02:38 AM
ALL IMPORT's Avatar
dont knwo but its gunna get hot.
why use nos when u can jsut add 5-7 psi more.
spraying straight meth into the charge pipe will help cool the air alot u wold be suprised how cool it makes the intake ( put it in where the nos would of went in), bump water straight meth , water dont burn its just to cut cost.. would be better to put he nos on the cooler everything helps.
also a full size radiator or atleast bigger than an small civic one
also i had a SETTRAB oil cooler kit that i was running with moroso oil pan. brought my tottal oil capacity up to 7.5qt. deff helped out.
selling the kit if u dont have one. got pics if your interested
Old 12-05-2009, 05:50 AM
blitz118's Avatar
Kyle's Underground Racing Twin Turbo Lamborghini Gallardo - 241mph at The Texas Mile
http://www.youtube.com/watch?v=lyj7D...layer_embedded
Quick Reply: running a mile
