What is a 2 step? ( clarification )
Old Jul 7, 2004 | 03:41 PM
ccivic's Avatar
Default What is a 2 step? ( clarification )
I've recently have been getting more and more into cars, as I have gotten my temps. My brother has always been into Hondas, and being around them for so long, I became very interested in them as well. I've been looking around these forums reading, and reading for the day that I get my car, so I know if I have problems I'll know what to do.
I've been hearing a lot about a '2 step' on this forum, and tried to search on here but nothing came up. I googled it and came up with 'http://www.rev-lite.com/Flat.html'. It's helped me understand a little of the concept but I still don't completely understand it. Could someone please explain to me <u>how a 2step works, and why people use them</u>?
Thanks a bunch.
Old Jul 7, 2004 | 04:45 PM
dragracerchic's Avatar
Default Re: What is a 2 step? (ccivic)
Here is a good definition for ya..
A two-step is an electrical ignition device that will "cut out" cylinders at random, after the engine rpm tries to exceed a certain point. This is basically a rev-limiter. The driver can set the low-side rpm of the two-step to be his launch rpm. With this, the driver can activate the two-step, and press the gas to the floor without over-revving the engine. You can recognize a two-step by the uneven Pop-Pop-Pop of the motor. Release the two-step, and the motor is unleashed, the throttle already wide open.
Old Jul 7, 2004 | 05:30 PM
SpeedDreamz.com's Avatar
Default Re: What is a 2 step? (dragracer101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragracer101 &raquo;</TD></TR><TR><TD CLASS="quote">Here is a good definition for ya..
Dayum good answer for a chic. Most turbo guys use them to build boost on the line also.
Old Jul 7, 2004 | 08:19 PM
ccivic's Avatar
Default Re: What is a 2 step? (dragracerchic)
How is the 2step usually activated?
Old Jul 7, 2004 | 08:20 PM
usually via a clutch switch.
Old Jul 7, 2004 | 08:23 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">How is the 2step usually activated?</TD></TR></TABLE>
I use a button on the staging brake.
Old Jul 8, 2004 | 05:55 PM
smokey2.0's Avatar
Default Re: What is a 2 step? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
I use a button on the staging brake.</TD></TR></TABLE>
can you post a picture? i'm thinking of getting a 2step, but i have no clue on where to mount the button!
Old Jul 8, 2004 | 07:57 PM
vaporboy12's Avatar
my button is mount right on my shifter
Old Jul 8, 2004 | 10:01 PM
Sinner's Avatar
Default Re: (vaporboy12)
is that the same thing as Full throttle launch? cause I have FLT and it sounds exactly like two step.
Nick
Old Jul 8, 2004 | 10:08 PM
STREETWERKZ's Avatar
Default Re: (Sinner)
isnt this the same thing as an MSD ignition box?
you can set TWO revlimiters on this..... most people set one at STOCK revlimit, and the other at their launch RPM, after your clutch is released, your revlimit goes back to stock.
Old Jul 9, 2004 | 07:58 AM
Rtype16's Avatar
Default Re: (STREETWERKZ)
We have been talking about this for a while all you had to do was search.
https://honda-tech.com/zerothread?id=918603
Old Jul 9, 2004 | 01:46 PM
smokey2.0's Avatar
Default Re: (Rtype16)
[QUOTE=Rtype16]We have been talking about this for a while all you had to do was search.QUOTE]
good thread, but it does not answer the original question of this thread. but you're right about the search option, doing one would had given him lots to choose!
Old Jul 9, 2004 | 02:17 PM
Rtype16's Avatar
Default Re: (smokey2.0)
Sorry. Quick and easy answers to your questions. A two step is basically a secondary RPM limit usually triggered by a switch of some sort. Mostly used in drag racing. This will help you stage the car more consistently at the line and also you can use this two step to also build boost off of the line.
Old Jul 9, 2004 | 02:35 PM
RI_TM's Avatar
what's recommended???(to be the best?)
Old Jul 9, 2004 | 03:03 PM
smokey2.0's Avatar
Default Re: (RI_TM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RI_TM &raquo;</TD></TR><TR><TD CLASS="quote">what's recommended???(to be the best?)</TD></TR></TABLE>
that's what i want to know, also pictures of where you mounted your switch would be appreciated
Old Jul 9, 2004 | 03:20 PM
Rtype16's Avatar
You can use a switch on the steering wheel or you can use the clutch switch already in your car.
Old Jul 9, 2004 | 03:23 PM
ModenaTwinTurbo's Avatar
its what Kanye West made his millions with.
Ed-
Old Jul 9, 2004 | 05:55 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">You can use a switch on the steering wheel or you can use the clutch switch already in your car.</TD></TR></TABLE>
88 crx, no clutch switch. that's why i'm asking, need some ideas!
turboLScrx
Engine Management and Tuning
Nov 5, 2018 02:19 PM
bluenc-87
Aug 25, 2016 08:12 PM
nvynuke18
Honda Civic (2006 - 2015)
13
Jan 28, 2011 03:50 PM
Wannab16a
Jan 14, 2003 06:41 AM
m0t0rhead
May 15, 2002 08:40 PM
