weight reduction/&dont needs
Old Jul 1, 2003 | 06:03 AM
MUGEN_B16CIVIC's Avatar
Default weight reduction/&dont needs
got a b16a1 in a civic ex 94 waht is something i dont need that will reduce my weight and my E.T.s i just need to lose points of a sec.
Old Jul 1, 2003 | 07:52 AM
93si's Avatar
what have you done to it?
Some things you can do
carpet, tar, ac, Cruise control, srs system, power steering
This is good for over 100lbs easy.
Old Jul 1, 2003 | 10:10 AM
crex23's Avatar
Default Re: (93si)
Speaker boxes, spare tire, passenger seat.
Old Jul 1, 2003 | 10:13 AM
maxpsi's Avatar
Default Re: (crex23)
Passenger seat is a good suggestion.
BTW, how hard is it to uninstall and install that seat on civics?
Old Jul 1, 2003 | 10:47 AM
89 JDM CRX's Avatar
Default Re: (maxpsi)
4 bolts .
Two in front , slide seat forward two in back
Old Jul 1, 2003 | 12:19 PM
FULLTHROTTLE's Avatar
Default Re: (GSRslowandswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRslowandswap &raquo;</TD></TR><TR><TD CLASS="quote">get rid of the bumper supports
and blah to those who say keep them. they are made for 5mph and less bumps...they don't do ****</TD></TR></TABLE>
WERD.
Old Jul 1, 2003 | 01:14 PM
feriocious's Avatar
get rid of the moonroof too. replace it with a carbon fiber panel. thats at least 30-40 lbs right there.
Old Jul 1, 2003 | 06:45 PM
HJLau75's Avatar
woo are you seroius, a moonroof weighing that much.
Old Jul 1, 2003 | 10:17 PM
bigTom's Avatar
Default Re: (HJLau75)
the moonroof if u have ever taken one out is surprisingly really heavy... it is basicallt the hold inside roof of ur car... its an entire frame with the glass... hence why the roof liner sits actually lower in car with a sunroof
Old Jul 2, 2003 | 12:07 AM
g2turbo's Avatar
if you remove the bumper supports are you talking about the whole metal piece that the bumpers (front and rear) mount to. IF you are how do you keep the bumper from flopping around or sagging in the center where it would previously have 6-8 bolts?? I wanted to do this to my DA and it seeme like both front and rear bumpers would just sag.
Old Jul 2, 2003 | 06:37 AM
crx12's Avatar
Default Re: (g2turbo)
I just made some brackets to support the bumper cover.
Old Jul 2, 2003 | 06:39 AM
AussieK24's Avatar
Default Re: (ek9t)
Moonroof is also weight that is mounted high in the car (about as high as you can get) High weight is GOOD to get rid of!
Old Jul 2, 2003 | 09:57 AM
snowseeker's Avatar
Two L brackets on top in the front and two L brackets on top in the back is plenty.
Old Jul 4, 2003 | 04:40 PM
g2turbo's Avatar
Default Re: (snowseeker)
cool thanks guys! I thought of that but was too lazy to follow through
Old Jul 4, 2003 | 04:54 PM
agturbo's Avatar
Take out the A/C if you already haven't
Old Jul 4, 2003 | 05:16 PM
88CRXHybrid's Avatar
Default Re: weight reduction/&dont needs (REDLINE7000)
sunroof in a 88 CRX weighs 27lbs.
Old Jul 4, 2003 | 05:45 PM
AllMoToRB18c's Avatar
Default Re: weight reduction/&dont needs (88CRXHybrid)
the bumper supports dont hold up the bumper....its still bolts to the radaitor support and the fenders and the lower radiator support....there is no bolts that hold the bumper to the support...and hes right theyre only for 5mph they dont do **** and u can also get a carbon fiber hood or a fiber glass hood....and look into lighter wheels...that also makes a diff
Old Jul 5, 2003 | 06:25 AM
g2turbo's Avatar
Default Re: weight reduction/&dont needs (AllMoToRB18c)
on my DA the bumper cover actually does bolt to the support. i know its different on the civics
Old Jul 5, 2003 | 09:29 AM
maxpsi's Avatar
Default Re: weight reduction/&dont needs (g2turbo)
Has anyone tried taking out there back seats in their 6th gen civic? I tried it last night. Out of 6 or 8 screws, I managed to only successfully unscrew one. The rest of them stripped and will not unscrew. Has anyone else had this problem when trying to do some weight reduction, and how did you deal with it?
Old Jul 5, 2003 | 03:05 PM
civic disobedience's Avatar
Default Re: weight reduction/&dont needs (maxpsi)
if you really want to get serious, and you don't live in an inclement climate, take out the heater/AC box, that is a good amount of weight between the box, cores, and motors. it is at least 35-40 lbs
Old Jul 6, 2003 | 11:12 AM
snowseeker's Avatar
Default Re: weight reduction/&dont needs (civic disobedience)
Than when it rains and your window fogs up you can spend quality time with your women on the side of the road insted of racing.
Old Jul 10, 2003 | 09:01 AM
maxpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone tried taking out there back seats in their 6th gen civic? I tried it last night. Out of 6 or 8 screws, I managed to only successfully unscrew one. The rest of them stripped and will not unscrew. Has anyone else had this problem when trying to do some weight reduction, and how did you deal with it?</TD></TR></TABLE>
Need help here, please
Xx98civiclxX
Apr 28, 2010 03:41 AM
climb_on
23
Mar 19, 2008 07:46 AM
cjames235
Jan 20, 2005 10:35 AM
ITR Demon
May 27, 2004 03:52 AM
Cyberorth
Honda S2000
12
Feb 3, 2002 09:28 PM
